When I had the rear wheel off to check the speedo drive unit, I had to undo the inner nut that holds it onto the speedo adaptor with the two grooves into it.
When tightening up that nut, as well as the other inner nut on the other side that holds the brake anchor plate on, how tight do people tighten these?
Hey, What's this oil on the floor?
