AdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 02-27-2007   #1 (permalink)
TRJack
I restored a 1967 T100C several years ago from the ground up. I have ~1000 miles on it as of now, but from the get go, it has blown what seams to be clean oil from the left exhaust pipe. This runs down the side of the head and also down the exhaust pipe. It does smoke, blue. from that side somewhat. Did I get a ring upside down, or could the timed breather valve be off? Thanks:
Jack B
Old 02-27-2007   #2 (permalink)
I'd suspect a cracked oil scraper ring or a too-large inlet valve guide or a guide, inlet or exhaust, loose in the head.
Mecchanica is offline   Reply With Quote
crap! hit left header pipe, where to get replacement? jeffz Twins Technical Talk 16 12-19-2007 01:16 PM
Flack damage on left header pipe n578md Twins Technical Talk 4 10-15-2007 04:15 PM
Left exhaust pipe blacker than right ... truebrit Twins Technical Talk 4 06-14-2007 12:58 PM
Left pipe turning cherry red 71Rigid Classic, Vintage & Veteran 16 06-06-2006 08:17 PM
Oil leaking around exhaust pipe ToddZimardo Modifications & Workshop Talk 3 02-05-2004 03:10 PM
