When U twist the throttle grip open, the cable pulls the slide up into the carb. body thereby "opening", (un-blocking) the passage of air/fuel mixture into the manifold. When U release the throttle, the slide flops down, re-blocking the flow and "rests" on the idle speed adjusting needle enough to keep the bike running. Hope this helps. Why U lose "power" at higher RPM's could be several things: Timing?, needle mixture level setting (too high/ too low ie: too rich/ too lean)? Float level (probably not if U have the plastic float), valves? etc.? Hope this helps.
...and the Rocket's red glare
The jig is up.
The news is out.
They finally found me!
Styx... (Renegade)
Ride each ride like it may be your Last!
