sticking valves - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!Honda PowersportsMotorcycle.com
Old 01-22-2007, 02:15 AM   #1 (permalink)
Favourite Bike: 1959 Triumph Trophy 650
Other Motorcycle: yamaha silverado 1100
What are the symptoms of 'sticking valves'? What causes it?
red59 is offline   Reply With Quote
Old 01-22-2007, 07:14 PM   #2 (permalink)
i think the cause is a too tight fit in the guide which need to be reamed to allow the correct play.the symptoms can be a loss of compression on one cylinder and sometimes a twittering noise
ben
when i ride i\'m always 17
peintremondain is offline   Reply With Quote
Old 01-27-2007, 12:44 PM   #3 (permalink)
Of course, they can only stick in the open position right, so they
will clatter like hell(as in too much value lash) They may also be
hitting the tops of the pistons. Again very noisy(and very serious).
What causes sticky values? Poor lubrication, improper installation
of new value guides, bent values, gored value stems cause by
improper lubrication, broken value springs.... Pick one..
Bruce Houghton.. .
bhought is offline   Reply With Quote
Throttle sticking. Help please. Colonel_Dorkus Twins Technical Talk 7 05-06-2007 05:56 PM
valve sticking? Programr Twins Technical Talk 10 01-15-2007 08:50 PM
Sticking clutch mushman Daytona Deliberations 1 12-02-2006 10:53 AM
Sticking Throttle Greyman Twins Technical Talk 7 08-01-2006 09:22 AM
Throttle is now sticking.... ROBD Twins Talk 5 06-17-2006 09:17 AM
