Clutch repair - 1972 bonnie 4 speed T120R - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-15-2007, 11:38 PM   #1 (permalink)
Well.....Based on my drive today it looks as if I am going to have to crack the primary chain case and do some clutch work.
Well....any suggestions? It seems as if the clutch isnt disengaging completely when I shift, in addition to that I have to let the clutch about 95% out before the bike starts creeping forward.....
PLEASE HELP! ....I will be doing this friday.
Any suggestions? Any tips or tricks....Can I just adjust the clutch retaining bolt on the pressure plate...or is this way more complicated?
Any help would be great!
Tim
twlynch is offline   Reply With Quote
Old 01-16-2007, 11:01 AM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
Start with a BOTTOM to TOP adjustment by the book.
Sometimes that will fix everything.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 01-16-2007, 03:10 PM   #3 (permalink)
the thing i found with my clutch is that there's about 3 layers which offer results:
1) full clutch adjustment, no covers need to come off
2) messing with the basket cover to straighten it out, primary cover comes off, but not the basket cover
3) opening up the basket, replacing springs, replacing worn cork plates if necessary.
i have so far done 1 and 2. the clutch is okay, but not perfect. i wish i'd just gone straight to #3 and gotten it over with. that's on the schedule for feb/mar, but i could have already done it.
and 1 and 2 offered significant improvements, don't get me wrong. i just hate to do something twice. i also hate to do more work than i have to, so you can see how this is my own personal punishment in hades.
move over, sisyphus. i need to shift from first to second and back again at 2 mph a few times....
Sic semper tyrannis
johnnypence is offline   Reply With Quote
Old 01-16-2007, 04:48 PM   #4 (permalink)
Well, first make sure you are getting the proper range on your ball-ramp inside the tranny cover, then adjust trhe rod and free play. If your cable is in adjustment and you still have insufficient joy, it's time to pull the primary cover again.
GrandPaulZ
Born Again Bikes
My Photo album
Old 01-16-2007, 08:16 PM   #5 (permalink)
interesting. that ball ramp looks like the previous owners never once put the bike in neutral at a stop. thanks. not to hijack the thread, mind you.
Sic semper tyrannis
Old 01-16-2007, 11:47 PM   #6 (permalink)
Thanks for the advice...I have the Triumph Shop manual and it says tighten the adjuster screw until the pressure plate is just about to lift, however, I see no lift...Should I just assume as soon as I feel the adjuster screw resistance that the pressure plate is starting to lift?
Old 01-17-2007, 01:01 AM   #7 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Tim,
Make sure your cable is backed right off first, then unlock the lock nut on the adjustment screw on the clutch outer (domed) pressure plate, and screw the screw in until you feel resistance. Then back it off 1/8th of a turn, and lock down the nut. This ensures the clutch operating rod is not in permanent contact with the ball ramp and clutch pressure plate - gets hot and wears quick if this is the case. Then adjust your cable starting at the gearbox end.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 01-17-2007, 03:04 PM   #8 (permalink)
Thanks!
Melbourne, Australia to Melbourne, Florida.
I haven't adjusted the gearbox side, is that documented in the Triumph Shop Manual?
Steps I have as of now:
1) undo the clutch lever adjustment
2) undo the nut on the pressure plate and turn screw until resistance is felt, then back off 1/8 of a turn, tighten nut back down.
3) Tighten down clutch lever adjustment nut. I think the manual said 1/8 inch play, maybe 1/16. (I am at work I don't have it in front of me).
(where does the gearbox cable adjustment go in these steps?)
Any help would be great.
Tim
Old 01-17-2007, 03:21 PM   #9 (permalink)
Gearbox level adjustment is the same as lever adjustment.
It's just that you should take most of the slack out at the gearbox to leave room to "play" with fine adjustment at the lever without that adjuster sticking way out.
GrandPaulZ
Born Again Bikes
My Photo album
Old 01-18-2007, 12:20 PM   #10 (permalink)
No matter what adjustment I make, I can not get the clutch to fully disengage. It makes some horrible noises when trying to go into first from neutral.
In addition to that, the back wheel spins slowly when in neutral and the clutch is disengaged. (On center stand I can see this).
Are there any tricks to this? I adjusted the pressure plate per the directions, I adjusted the gearbox adjustment (made sure no constant tension on clutch mechanism in gear box, and then I tried adjusting the clutch lever...no luck.
Please HELP!
Tim
Bonnie T120R What does the "R" Mean? MotorPal Classic, Vintage & Veteran 5 09-20-2007 10:39 AM
Need a 1970 T120R Repair manual OldF Twins Technical Talk 3 11-15-2006 01:01 AM
How hard is it/how much money does it cost to repair a broken clutch cable? monSTAR Speed Triple Forum 19 07-25-2006 06:03 PM
Sprint Triumph / Daytona & Speed Triple 2002 Repair Manual pdf detjan Sprint Forum 8 05-14-2006 05:49 PM
[Repair Manual] for Speed Triple year 04 nours Speed Triple Forum 10 11-02-2004 08:06 PM
