primary oil - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew BonnevilleHonda Powersports SportbikeTrackGear
Old 01-13-2007, 04:53 AM   #1 (permalink)
firedog
i'm a bit confused on what oil to use in primary.. i've been told to use atf . But some people say the oil from the primary mixes with the engine oil. I wouldn't want that. The bike i'm working on is a 1969 tr6r with no modifications. any help would be appreciated...
Old 01-13-2007, 05:32 AM   #2 (permalink)
Triumphs up to and including 1969 have the primary oil separate. The 70 and later, with the big vent tube from the upper rear of the primary inner cover, merge the oil from the engine and the primary together. Your bike can and should use either very light synthetic oil ( like 5 W 20 ) or synth. ATF in the primary.
Mecchanica is offline   Reply With Quote
Old 01-13-2007, 03:40 PM   #3 (permalink)
gbc
Favourite Bike: My Thunderbird Sport
gbc's Avatar
Other Motorcycle: Rocket III
Extra Motorcycle: Equal Billing
I just finished putting Royal Purple synthetic ATF in the primary of my 68 Bonneville. I also switched to the RP synthetic gear oil in the gear box. What a difference. The bike shifts better than it ever has and clutch feels really smooth. I highly recommend the change.
gbc is offline   Reply With Quote
Primary Oil dorkingbonny Vintage Technical Tips & Tricks 48 10-21-2009 11:25 AM
Trans And Primary Oil aceaceca Classic, Vintage & Veteran 4 10-26-2007 12:02 PM
primary oil dirtyharry Classic, Vintage & Veteran 6 06-13-2007 03:30 PM
Primary Drive Oil dorkingbonny Classic, Vintage & Veteran 8 10-30-2006 12:21 PM
What oil for primary chain case if???? bushybester Classic, Vintage & Veteran 2 08-28-2006 10:21 AM
