Triumphs up to and including 1969 have the primary oil separate. The 70 and later, with the big vent tube from the upper rear of the primary inner cover, merge the oil from the engine and the primary together. Your bike can and should use either very light synthetic oil ( like 5 W 20 ) or synth. ATF in the primary.
