Motorcycle.com
Old 01-08-2007   #11 (permalink)
I don't have the choke...the previous owner removed it. I live in FL, I haven't really needed it.
I turned my throttle stop screw a little, I am going to crank it up during halftime of the UF / OSU game. Maybe this will help.....if not do I adjust the float? Anyone have instructions on how to adjust the float? Any info would be great.
You guys are the best!
Tim
twlynch is offline   Reply With Quote
Old 01-08-2007   #12 (permalink)
I took it for a ride and adjusted the throttle stop screw on both carbs to run idle at 1K RPMs. Is this to high? Seems to not stall when I engage the clutch to stop from higher speeds. One thing that I noticed if I am stopped and idling without touching the throttle it will run about 30 - 45 seconds then it will quit. I have to tickle the carbs to kick start it back up. Is this because the carb is using a good amount of fuel idling and the bowl goes empty? Any idea why this happens I am real curious.
Thanks! ......
Tim Lynch
Old 01-09-2007   #13 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
You may need to remove the carbs and give them a THOROUGH soaking in Berryman's Chem-Dip 1/2 hour minimum (METAL PARTS ONLY).
Clean your air filters, too.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 01-10-2007   #14 (permalink)
It seems to run now that I upped the idle.
I just turned the throttle stop screw on both sides.
IDLE RPM around 1K.
Till next time..... I got to get this clutch lever thing figured out....it is very hard to disengage the clutch...
Tim
Old 01-10-2007   #15 (permalink)
Are you talking about disengageing the clutch before start up? If so, I have a few tips. Let us know. I've found 1000 rpm at idle when warm is just right. I've idled it at 750 rpm, but drops off. Sounds good tho. Being I seem to like fiddling with carbs. I've invested in some mercury sticks and tuned them and forgot them. A good mechanic reminded me that different barometric pressures and humidities can make a bike run alittle different from one day to the next.
okiecityflash is offline   Reply With Quote
Old 01-10-2007   #16 (permalink)
okiecityflash -
I can not disengage the clutch and crank my bike. I have to put it in neutral to kick my bike over....is this wrong? I don't know any different. My bike seems to run pretty good with the idle set at around 1K RPM, I guess I will leave it there until it starts stalling again!. Off that note, I am trying to figure out why my clutch lever takes an unbelievable amount of pressure to disengage the clutch. I really think the 3 clutch springs are either to strong or to tight....does this sound right?
Tim
955i engine stalls, need help Torro Daytona Deliberations 4 03-04-2008 11:20 AM
Engine stalls under 2K in first (on take off) 00 ST cafejim Sprint Forum 8 05-19-2007 07:19 PM
955i 98 engine stalls eytriumph64 Modifications & Workshop Talk 4 02-03-2007 12:33 AM
Engine stalls on initial startup geofflowe Sprint Forum 11 05-08-2006 08:53 PM
engine stalls:?? I think my clutch is dragging tjk2134 Sprint Forum 21 04-27-2005 11:55 PM
