Motorcycle.com
Old 01-06-2007   #1 (permalink)
All the discussion about parts interchanging across the years, and my current projects, have raised a question about engine mount locations and engine stands.
I'm no welder, but if I had a local shop weld up an engine stand that will fit my '66 650 cases, will it fit other engines besides unit 650s? Which ones?
As for now I am using an old engine box (rectangle of 2x6s), but I am going to try to find time to take a welding class. In the meantime I might get extravagant and have one welded up. More likely to do it if it has broader application.
oldebonnie is offline   Reply With Quote
Old 01-06-2007   #2 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
I believe anything from '63 to '70 will be compatible; not sure if the OIF years stayed common in layout, but they are all the same from '71 through the end (I believe).
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 01-06-2007   #3 (permalink)
[ This message was edited by: KADUTZ on 2007-01-28 00:28 ]
KADUTZ is offline   Reply With Quote
Old 01-07-2007   #4 (permalink)
Thanks guys. I figured the unit 650s engine mount holes were all in the same position, and that 750s were the same. How about the 500s? If they are not the same as the big twin units, are they close enough that making one of the mounts adjustable, or using mounting plates, would make the same stand work for both?
Old 01-09-2007   #5 (permalink)
The unit 500 has no outboard rear mounts or front mount, unless you bolt on the two plates. And the bottom center lug stud is smaller. I'd build another of those magic boxes..... cheap and versitile. Use 1 X 8's about 9 1/2 X 12" and it will do a whole bunch of neat jobs. No welding needed.
Mecchanica is offline   Reply With Quote
Noisy Engine / Exhasut Bolt question ... kazjim955 Sprint Forum 9 08-12-2007 06:12 PM
Engine Bolt Questions - '05 Crash Protector Installation BoBubbaBill Sprint Forum 4 05-28-2006 01:36 PM
Rear engine mount horsis The Rocket Science Forum 4 06-21-2005 11:57 AM
Engine bolt toque TTBONNE Classic, Vintage & Veteran 2 01-20-2005 03:57 PM
bottom engine bolt question Classic, Vintage & Veteran 5 10-18-2004 04:23 PM
