head gasket annealing - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-27-2006, 10:18 PM   #1 (permalink)
firedog
can anyone tell me the steps to annealing a head gasket?
Old 12-27-2006, 11:30 PM   #2 (permalink)
I just use a cheapo propane torch, sneak into the kitchen when wife is not around turn big electric burner on high to help keep the gasket hot, then torch the gasket evenly until red hot, again evenly and drop it in one of her shallow cookie pans of cool water. Has always worked for me, gasket comes out like new. The burner is optional, but I've found it helps keep the gasket evenly hot while torching it and using wifes stove is at your own risk.
triumphtimes is offline   Reply With Quote
Old 12-27-2006, 11:41 PM   #3 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Firedog,
This is what I do.....
Give the old one a clean, with a kitchen scouring pad (not steel wool) to get any carbon deposits of it. Light use of 600 wet/dry paper is also appropriate for heavy deposits, but be careful not to use it too much in one area, or you'll thin out the copper.
Fill a large container of water -eg 2 gallon plastic bucket full to the top, large stewing pot ,etc. It must be big enough to fit the whole gasket in at once. Place it nearby your "heating plant".
You'll need a gas fired heater of some sort. An LPG torch, or large burner on the stove. I use my BBQ, with the grill out, and only 1 burner row alight. Grip the gasket with a long handled device. I use multigrips with a large rubber band around the handles (so I don't drop it). I grip the gasket around (over) one of the larger holes (not the hole(s) between the cyclinders, but the next ones out towards the sides), try not to grip over the area that the gaskets seals - ie around the cyclinder holes. Wearing welders gloves, hold the gasket in the flame, moving it about to make sure you heat the whole gasket to a cherry red. This may take a minute or two, depending on the heat source. The hottest part of the blue flame is the tip of the inner/lighter part of the flame - this is where you need to be.
Once you reckon you've heated the whole gasket to cherry red, take it off the flame and immediately dump the whole thing in the bucket of cold water. Best to let it fall in without the gripper/pliers/etc attached, as you may bend the gasket.
Take it out, dry it off, and it's ready to re-use.
That's the method I use, but maybe one of the pro mechanics on the forum has a better way of doing it.....?
Pete
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 12-28-2006, 01:02 AM   #4 (permalink)
Favourite Bike: '67 Triumph Bonneville
If time is money, that last method is probably worth 5X the cost of a new gasket!
hee hee
If you are like me, you'll do it to get the gasket on the bike NOW, instead of waiting for the new one to get here...
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 12-29-2006, 03:02 PM   #5 (permalink)
ironduke
From which supplier do you buy your copper gaskets?
Old 12-29-2006, 09:11 PM   #6 (permalink)
firedog
bought all my parts from Rabers parts mart. The package the new gasket came in said anneal efore useing.
Old 12-30-2006, 11:30 AM   #7 (permalink)
If it said to anneal before using, it was a used gasket.
New gaskets should be ready for use.
GrandPaulZ
Born Again Bikes
My Photo album
Head gasket sealer flyrodder Classic, Vintage & Veteran 6 09-21-2006 12:51 PM
Head Gasket?? triumphrdr Speed Triple Forum 14 11-12-2005 09:41 PM
Head Gasket??? flick427 Twins Talk 8 08-02-2005 12:36 PM
head gasket Triumph, Models & Dealers 0 08-18-2004 01:23 AM
Blown Head Gasket Classic, Vintage & Veteran 4 07-10-2004 12:09 AM
