HELP!question about installing ard magneto? hit a little snag! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-26-2006, 06:36 PM   #1 (permalink)
hey guys my Buddie and i starting to install the magneto. we ran into a little snag when tighten the center bolt with the timing pin in. when we went to tighten done the center bolt the pin bent and would come out. so we took it apart and noticed the pin had bent like a S. were we supposed to put in gear and install the plugs to help the crank from rotating.has anybody else have this problem. who has installed this before. can i call you for some insight.pm or email me if you can help.
dgfironworks@optonline.net
thanks
[ This message was edited by: dgfironworks on 2006-12-26 18:10 ]
support www.choppertown.net
dgfironworks is offline   Reply With Quote
Old 12-26-2006, 06:45 PM   #2 (permalink)
some pics of the instll would be great. where you installed the ard coil and black box also.
thanks
Old 12-26-2006, 08:11 PM   #3 (permalink)
ok found out why the pin bent. didnt have the outer bolts snug enough. still would pics of your set up.
thanks
ok guys got a new question for you! got my ARD magneto. dgfironworks Classic, Vintage & Veteran 18 07-19-2010 03:03 PM
joe hunt magneto vs lucas magneto preunit13 Classic, Vintage & Veteran 20 09-06-2008 09:03 PM
ok guys got a new question for you! got my ARD magneto. dgfironworks Maintenance & Workshop Talk 1 12-12-2006 06:18 PM
ARD magneto? dgfironworks Maintenance & Workshop Talk 1 12-04-2006 08:18 PM
ARD Magneto? Bonnevillian Classic, Vintage & Veteran 17 06-28-2006 09:54 PM
