Old 12-22-2006   #1 (permalink)
Favorite Bike: 1973 Tiger 750
jonkull's Avatar
Does anyone know if cold weather will affect the kickstarter on a bike?
My Tiger has almost always started up real easy in one kick but since the cold weather has come I find myself kicking like a fiend...over and over and over and over... It's not so much as the engine not wanting to turn over as much as the lever being so stiff I can barely move it. I have to basically jump on it with the entire weight of my body to get it to move the first couple times. Once I get it started and it runs for a few minutes if I kill the engine it will start again in one real easy kick. Could this be the cold or should I look at other things? The last 'repair' I did was replacing the clutch cable if that means anything.
Thanks!
jonkull is offline   Reply With Quote
Old 12-22-2006   #2 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
I didn't think cold weather could affect a kickstarter that much, but maybe it's a combination of close tolerances in your kickstart mechanicals combined with too heavy oil in the primary?
Wierd...
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 12-22-2006   #3 (permalink)
jonkull's Avatar
Wierd...
As far as the oil I'm using whatever was recommended in the Owners Manual...can't remember the weight off the top of my head. Could the clutch be an issue? The cold weather and my cable replacement started around the same time. Or does the clutch not factor into it?
Old 12-22-2006   #4 (permalink)
Yes, cold weather will make it harder to kick over. Either Primary oil or engine oil of too heavy a grade will affect starting. Once heated up a bit it will be normal. I've had to use hot air gun on my ATV with 20w50 oil to warm things up first . You could try this on your primary first to see if it helps. Mike
mike07 is offline   Reply With Quote
Old 12-22-2006   #5 (permalink)
Moderator
As there is a fairly direct path for the force applied to the kickstarter to pass through the mainshaft, through the clutch, along the primary chain to the crankshaft, I can't really see how or where oil viscosity would have a measureable effect of increased pressure required to get the crank rotating.
GrandPaulZ
Born Again Bikes
My Photos
Old 12-22-2006   #6 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
Jonkull,
IMHO, this could be caused by too much tension on the primary drive chain. Colder weather will "shrink" it even further, causing it to bind against the tensioner and "distort" the clutch basket. When you get it going, it heats up, expands, and the issue goes away. Check the tension and if too tight, back it off 1 revolution of the adjusting bolt/screw.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 12-22-2006   #7 (permalink)
[ This message was edited by: KADUTZ on 2007-01-28 00:08 ]
KADUTZ is offline   Reply With Quote
Old 12-22-2006   #8 (permalink)
Favorite Bike: '71 Norton Commando
CommandoRdster's Avatar
Other Motorcycle: '07 Scrambler
Extra Motorcycle: '71 BSA Victor B50MX
Pull in the clutch, and cycle the kickstarter through a few times, to free up the clutch plates. See if that helps a bit. I can't imagine it being cold enough in Burbank to cause a problem.
ANIMAL RESCUE SITE-Please go there and click on the purple button!
CommandoRdster is offline   Reply With Quote
Old 12-22-2006   #9 (permalink)
jonkull's Avatar
On 2006-12-22 21:23, KADUTZ wrote:
Just as a reference point what is cold as in how many degrees.
This bike has been a real big PITA since I got it. Anyway...
Well I haven't actually checked a thermometer but it's been in the lower 30s overnight and probably in the 40s when I leave for work. Mid day maybe in the mid-upper 50s. This issue almost always occurs in the early morning. If I leave work at lunch time it will start OK and at the end of the day (after 6pm) it will take 2-3 kicks but early in the morning it's another story. Today I counted 16 kicks before I could get the engine going. The first 10 or so the lever barely moved. A couple more kicks got it half way down then after a couple more kicks it went all the way down. Once the lever makes it through a full motion it will start in a kick or two. It's just getting it to make that first revolution that's a real chore. I've had This bike since May and it's just started doing this in the last 2-3 weeks...up until then it was pretty quick and easy to start. The only 2 things that have changed within that time frame are the weather and the clutch cable.
Old 12-23-2006   #10 (permalink)
[ This message was edited by: KADUTZ on 2007-01-28 00:09 ]
Cold weather is here Cburt Speed Triple Forum 6 12-02-2007 10:23 AM
Cold Weather Riding oldndumb Sprint Forum 22 11-23-2007 10:07 PM
Cold Weather?? wonderdog Biker Hang-Out 11 01-30-2007 08:58 AM
Cold weather starting? billybob235 Twins Technical Talk 19 01-24-2007 03:44 PM
cold weather riding HeyMan Biker Hang-Out 20 01-08-2007 12:05 PM
