1971 T120R oil in frame fuel tanks??? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 11-18-2006, 07:44 AM   #1 (permalink)
Main Motorcycle: All of them
Other Motorcycle: 1971 Triumph Bonneville
Extra Motorcycle: a few
Hey people,
Can anyone please tell me what other year model tanks will fit on my 1971 oil in frame bonnie.
Cheers!!! :hammer:
valiantbultaco is offline   Reply With Quote
Old 11-18-2006, 07:49 AM   #2 (permalink)
Main Motorcycle: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
1972 up t120/t140 tanks
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is offline   Reply With Quote
Old 11-18-2006, 12:19 PM   #3 (permalink)
DAGAD's Avatar
Any 3 or 4 imp gallon oil in frame tank will fit. Even the BSA tanks will fit. I have also seen a TR5T adventurer / Trophy Trail alloy tank on a T140W (TSS).
Roy.
Old 11-09-2012, 04:18 AM   #4 (permalink)
Main Motorcycle: 1050 speed 3
Other Motorcycle: daytona 995i 2005
Extra Motorcycle: 1050 speed three 2009
good puzzler for you sages, what modern front end will fit into a 650 bonni oil in frame, ie.by changing the top and bottom yolks, I need to up rate whole front end. P.S. to our colonial friends the yolks hold the forks onto the steering head, where the hell you got triple trees from god knows... have a think cheers lads!!!
gabow1815 is offline   Reply With Quote
Old 11-09-2012, 10:45 AM   #5 (permalink)
Main Motorcycle: T140E
Yolks are found inside egg shells. Yokes are what you are looking for. A yoke is a beam that connects 2 pulling animals among other meanings. You can see where yoke becomes appropriate to hold the front forks to a motorcycle frame. But you should also be able to see how triple tree is appropriate. 2 fork tubes/legs and 1 stem = 3 things that need to be held in position. The term tree has more than 1 meaning (shoe tree, coat tree) where the tree holds something. Both terms fit.
Scott
Rookster is offline   Reply With Quote
Old 11-12-2012, 04:14 AM   #6 (permalink)
Well done Rookster, you spotted the selling mistake now spot me a front end!!
Old 11-12-2012, 04:14 PM   #7 (permalink)
Main Motorcycle: Triumph T140 & TR7
Other Motorcycle: Guzzi T3
Extra Motorcycle: Another Guzzi T3
Good reply Rookster! You've explaind soemthig that had puzzled me for ages, ie: 'triple trees'. Sounds daft to limey ears but maybe yokes (or yolks) sounds just as daft to you yanks?
As for front-ends gabow, if you get onto the T140 forum (a much smaller forum than this), one of the members on there, from Cornwall, has fitted modern upside-down front-ends onto several Triumphs and I'm sure he'd be glad to advise. Just google T140 forum (not T140.com, that's Shropshire Classics website - I don't recommend them for good advice). If you can't find it let me know on here and I'll try to post a link.
JohnA is offline   Reply With Quote
Old 11-12-2012, 04:35 PM   #8 (permalink)
gabow,
I don't know the answer to your question, but you can help yourself here without demanding info. You need basically 2 measurements to get you going in the right direction: stem length & stem diameter. Measure the length of your stem and the diameter. Now start trolling ebay for GSXR or R1 front ends and ask the sellers for the same measurements. If you can find one that is the correct or close enough length then you can always have it cut to the correct diameter. Replacing stems can get tricky but is doable. You are going to have the get new bearings and races but that is the least of your worries at this point.
Scott
Old 11-13-2012, 02:21 AM   #9 (permalink)
Now this is a blast from the past!
Old 11-13-2012, 04:57 AM   #10 (permalink)
Nice one JohnA, I'll get in touch, by the way I'm a Celt not a limey....loves u G.
Paint issues with Bonneville Fuel Tanks SGTSnacks Twins Technical Talk 7 09-12-2007 07:05 PM
Plastic Fuel Tanks John21 Sprint Forum 8 08-26-2007 11:25 AM
Fuel Tanks Scouser Twins Technical Talk 2 08-20-2006 09:38 PM
Cool Fuel Tanks Thrux-ton-up Club Cafe' 10 01-09-2006 11:18 PM
1971 T120r gearbox noise rambo Classic, Vintage & Veteran 0 06-13-2005 05:57 PM
