DorkingBunny,
The primary uses the same oil as the engine. When you change the engine oil, dump the sump oil, and the primary chaincase oil as well. Lubricate the primary chaincase with 150mL of standard engine oil. When the engine is running, oil vapour is passed to the primary chaincase from the crankcase via the breather holes in the left hand crankcase. This vapour keeps the primary "topped up", and you should only need to add/replace oil in the primary chaincase when you dump it for maintenance.
Lot's of opinions on the forum about the best oil to use. Personally, I use Penzoil 20W50 for air cooled 4 stroke engines -red stuff - never had any issues with it. Up to you.
Per Ardua Ad Astra
