BikeBandit
Old 09-23-2006   #1 (permalink)
hey y'all, i was working on my dadgum ignition switch this morning before i had enough coffee -- it pulled off in my hand and left the wires dangling before i could catalog which wire went where.
can anybody help?
i think i'm buying one of those big wiring diagrams today ...
Sic semper tyrannis
johnnypence is offline   Reply With Quote
Old 09-23-2006   #2 (permalink)
never mind. trial and error pays off, without blowing a fuse!
vroom vroom.
Sic semper tyrannis
Old 09-23-2006   #3 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
The sparky wire goes on one pin, and the other two go on the other (double) pin.
hee hee
Vroom vroom is good!
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 09-23-2006   #4 (permalink)
The 72 still used that goofy huge switch with about five different poles, most with two blade conectors, if it's stock.
Use an ohmmeter and make a chart, a grid. Along the left side, each row should represent the switch position...O for off, 1 for first postion (or ON if only an on/off switch). Then in columns label across the top with the poles which you have numbered on the switch. Note which ones are connected to each other in each position by putting an X in the box where the row and column intersect. Then look at the pattern. It should tell you what's up. In the off position there should be at least one terminal which is isolated from all the others. This would be the hot lead. If it's a two position switch, then all the others would be connected when the switch is ON. If it's a three position switch....on off lights or acc....then in the first postion, those things which work when the igntion is on, but lights are off, like brake light, idiot lights, horn, etc., would be hooked to the first position poles, and the lights to the second position poles.
Mecchanica is offline   Reply With Quote
Ignition Switch - HELP stamp Trophy 3 11-09-2007 11:34 AM
Ignition Switch loski67 The Rocket Science Forum 10 06-24-2007 08:19 AM
Kill switch versus ignition switch? boredinocala Sprint Forum 13 09-10-2006 09:03 PM
ignition switch Spyke Modifications & Workshop Talk 2 08-07-2006 07:59 AM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 12:50 PM
