Trident-Exhausts.comBikeBanditMotorcycle.comAdvanstarMotorcycleShows
BikeBandit
Old 09-20-2006   #1 (permalink)
Which brand and type of head gasket sealer do you recommend? Or do you just use the gasket without any sealer?
Thanks,
flyrodder
flyrodder is offline   Reply With Quote
Old 09-20-2006   #2 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
No sealer, but get a good quality gasket, one that's all copper if they're still available. It's best not to use any sealer that hardens on any of the top end components. I used Gaucinch on the base of my cylinders once and it was nearly impossible to lift the jug later.
Anyone with better knowledge, speak now: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 09-20-2006   #3 (permalink)
No sealer needed, just use a good quality gasket with correctly torqued head bolts!
drummerboy is offline   Reply With Quote
Old 09-20-2006   #4 (permalink)
Favorite Bike: 77 Bonneville
OzBloke's Avatar
I concur with Jim and Drummer - just the copper gasket and torque down correctly. I use Hylomar blue on the paper cylinder base gasket, only because I've had a few problems with leaks there. The rest of the paper gaskets I use without any sealer.
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 09-20-2006   #5 (permalink)
Most modern composite gaskets available today, outside of the solid copper headgasket, are made of "Klinger" material, which has sealer encapsulated in microballoons in the gasket. Make sure the surfaces are clean and then just snug down the parts, once the engine heats up, the balloons burst and the sealer does it's thing. These gaskets have a shelf life and may get brittle from sitting exposed to air. Keep spares in a sealed bag with as much of the air pressed out as possible.
The solid copper headgaskets can be reused if annealed.....heat to orange-red for 15 seconds or so and quench in water. This softens it up and makes it able to seal when the head is torqued. Retorque until there is no change in the bolt tension, usually once or twice. Readjust valves each time, if necessary.
Mecchanica is offline   Reply With Quote
Old 09-21-2006   #6 (permalink)
Thanks! I appreciate your helpful comments.
flyrodder
Old 09-21-2006   #7 (permalink)
Yer welome. Good opportunity to post some general information that most people can use.
Which Gasket sealer, there are so many Ahobie17 Classic, Vintage & Veteran 10 11-06-2007 10:44 PM
Head Gasket?? triumphrdr Speed Triple Forum 14 11-12-2005 08:41 PM
Head Gasket??? flick427 Twins Talk 8 08-02-2005 11:36 AM
head gasket Triumph, Models & Dealers 0 08-18-2004 12:23 AM
Blown Head Gasket Classic, Vintage & Veteran 4 07-09-2004 11:09 PM
