Motorcycle.com
Old 08-27-2006   #1 (permalink)
Favorite Bike: bonneville
Other Motorcycle: speed twin
What oil is recommended for primary chain case with synthetic type clutch plates ( not cork)? If any????
I have read some where that one can add a bit of turpentine to the oil if the correct grade oil cannot be obtained.
I have found that as soon as I add the oil the clutch slips and I cant start the bike.
what is the coarse of this?
Thanks
BB
bushybester is offline   Reply With Quote
Old 08-27-2006   #2 (permalink)
Hi Bushy,
First up have you got the clutch springs set to the correct tension ?
With the clutch disengaged, depress the kick start, does it spin true and does the top pressure plate lift squarely or is there a wobble, tension up the springs to give an true run, i.e. no wobble
I would keep the chain-case off untill you can crank the engine over using the kick-start, at least this way you can see whats going on and you will be able to see if the clutch is slipping.
Second, the oil in the primary chain case should be sae20, Castrol lite was recomended but I have not seen this for many years so I use AWS 46 hydraulic oil, made by Castrol
If the oil you have used is too heavy the clutch plates tend to stick together making it impossible to disengage the clutch
If the oil is to heavy you can clean the clutch out using paraffin oil (kerosene) then refilling the chain-case with the correct grade oil.
As you state you have clutch slip I can only think you have not adjusted the clutch correctly, if you have the correct
slick-shift gear-box fitted you may have the slick-shift mechanism out of adjustment.
I replaced the clutch on my Tiger 100 using synthetic inserts and have run with hydraulic oil in the chain-case with no problems. Just remember to change the oil at regular intervals, to offset the effects of condensation.
H.T.H. Regards TripleGuy
TripleGuy is offline   Reply With Quote
Old 08-28-2006   #3 (permalink)
THANKS TRIPLEGUY, CHECK YOUR PM's
BB
[ This message was edited by: bushybester on 2006-08-28 09:37 ]
Wrong primary-case = wrong timing happyray Classic, Vintage & Veteran 3 04-05-2007 10:27 AM
primary chain tension htown16 Classic, Vintage & Veteran 1 04-03-2007 12:19 AM
Primary Chain Case!... twlynch Classic, Vintage & Veteran 18 03-27-2007 07:23 PM
Primary chain case crazypierre Classic, Vintage & Veteran 13 02-19-2006 12:31 PM
Cub Primary Chain fido Classic, Vintage & Veteran 1 08-07-2005 12:28 PM
