Motorcycle.com
Old 07-21-2006   #1 (permalink)
When I give my bike alot of gas it feels like the clutch slips, and the motor reves really high and then kinda equalizes. I seem to notice most often when I am passing, but I also notice it when the bike is cold in the morning as well. Any advice?
uncliggi is offline   Reply With Quote
Old 07-21-2006   #2 (permalink)
Favorite Bike: 1959 Triumph Trophy 650
Other Motorcycle: yamaha silverado 1100
Well, if everything is adjusted right, I'd say your clutch plates need replaced, and or springs. Sometimes a slipping clutch can be felt when you kickstart it.
red59 is offline   Reply With Quote
Old 07-21-2006   #3 (permalink)
Depending on state of tune, and whether you've already adjusted everything correctly, it could be as simple as a cable/pressure plate/spring adjustment....assuming theres no Slick 50 or other oil treatment in the oil. Or it could be worn discs. Then in rare instances if it has extreme mileage or neglect "other related parts" could be worn...but doubtful. Start low$$$ and work up to high$$$ You could buy a gasket and pull it apart and give the spring screws 1+/- turn in (make sure the springs don't coil bind afterwards though) Manuals show how to adjust everything....of course you could just rip everything apart and check everything, mic. the discs etc.......Clutch set and new springs will most likely cure it though.
"I Live In My World, And I Am My Own King In My World, Whether It Be A Garbage Dump, Or In The Desert Or Wherever It Be".........Charles Manson
texspeed is offline   Reply With Quote
Clutch Slipping in 3rd gear Hedge Twins Technical Talk 13 09-19-2007 10:20 PM
Slipping Clutch? TwistyRD Modifications & Workshop Talk 1 06-26-2007 03:43 PM
R3 clutch slipping tommythistommyt The Rocket Science Forum 11 07-03-2006 06:10 PM
Clutch is slipping when cold??? 64Chop Classic, Vintage & Veteran 4 11-16-2005 12:36 PM
clutch slipping greenocktriple Speed Triple Forum 3 06-22-2005 01:58 PM
