Idling High -- 77 Bonne - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.comNew BonnevilleMotorcycle.com Classifieds!Honda Powersports
Old 06-25-2006, 03:47 PM   #1 (permalink)
Installed some new Amals and cables. When bike starts up it idles very high. I have increased the slack in the cables to allow the sliders to be in a sitting position. However it still idles high. I think they are not sitting completely down. I don't remember the RPMs but I would guess around 3-4k.
I have tried using my old cables and same thing happens. Old and new cables are same size.
I don't have a manual for the carbs so its a little difficult to troubleshoot. I am assuming there is some fine tuning that needs to take place.
Any Ideas? Thanks.
on my eighth bonneville/thruxton.....anyone else have a love hate relationship with these things?
tokarz33 is offline   Reply With Quote
Old 06-25-2006, 03:55 PM   #2 (permalink)
Where are your air screw sitting at? What is the main, pilot and needle and position sitting at?
You didn't over torque the carbs when mounting did ya?
[ This message was edited by: Bonnevillian on 2006-06-25 14:00 ]
Bonnevillian is offline   Reply With Quote
Old 06-25-2006, 03:58 PM   #3 (permalink)
All I can tell you is that the clip is in the middle position on the needle. No idea on the other stuff.
I don't believe I over tightened it.
Old 06-25-2006, 04:00 PM   #4 (permalink)
If your air screw is out too far then it is mimicing a air leak.
Start at 1.5 turns out....
Here....read THIS!
Old 06-25-2006, 04:05 PM   #5 (permalink)
Yeah, I have seen this site before but nothing talks about troubleshooting high idle except the cables.
Old 06-25-2006, 04:08 PM   #6 (permalink)
I read a little further. I think I might be on to something.
Old 06-25-2006, 04:14 PM   #7 (permalink)
Stock jetting on a 77 Bonnie is:
You bought 30mm Amals right?
190 Main
#3 slide
Needle should be in the middle and be a 106
Old 06-25-2006, 07:24 PM   #8 (permalink)
I will have to verify those numbers.
One of the things I am noticing is that the slide is not sitting at the lowest position. I think that is the real issue.
Old 06-25-2006, 08:03 PM   #9 (permalink)
One more thing. I am running Norton pipes. I am just trying to get the idle down so I can fine tune.
Old 06-26-2006, 10:32 PM   #10 (permalink)
Get er fixed?
Idling High 007British Hinckley Classic Triples 7 09-24-2007 11:18 AM
S3 idling RPM? Crogers Speed Triple Forum 3 09-15-2007 10:59 AM
Idling high Blairman Sprint Forum 9 09-06-2007 09:25 AM
Idling High bosoxrider Twins Talk 8 08-15-2005 08:33 AM
Idling sangsters Triumph SuperSports 4 08-30-2004 04:50 PM
