out of my transmission - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda Powersports Motorcycle.com
Old 06-23-2006, 03:01 PM   #1 (permalink)
77bonniehotrod
Since my rebuild on a 77t140v I now can't for the life of me change gears.No neutral no start.Can someone tell me if thegearbox camplate sits between 2nd and 3rd or on 3rd gear on the plunger.Also does the camplate quadrant sit on the top or bottom of 2nd gear.Just need some help aligning these stupid gears(mistakes i made)any help would be much appreciated.Thanks for any time and help.
Old 06-25-2006, 05:16 AM   #2 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Hotrod,
If you set the camplate up halfway between 2nd and 3rd, you will find a "false neutral". When you go to set the quadrant (ie. put the inner gearbox cover all the way home), lift the quadrant so that the second tooth from the top aligns with an imaginary line through the centre of the camplate shaft and the hole where the gearchange shaft goes through the engine. Then push or lightly tap the inner cover home.
Just today put my cluster back in, and this method works fine. I can send a picture if you like...
Pete
[ This message was edited by: OzBloke on 2006-06-25 03:18 ]
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
8 Speed Transmission? TheBoatDude Biker Hang-Out 7 09-01-2007 04:16 AM
06 Transmission T100Tom Tiger Chat 11 08-06-2007 02:46 PM
transmission ratios? Chinookmark Speed Triple Forum 2 07-28-2006 02:16 PM
transmission/clutch again CaptainMorgan Speed Triple Forum 19 06-22-2006 06:21 AM
transmission rebuild help Maintenance & Workshop Talk 0 04-30-2005 09:14 PM
