Teflon tape on fuel fittings ? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-23-2006, 08:10 AM   #1 (permalink)
Hey y'all,
I had a fuel fitting crack on me (the one at the bottom of the main petcock). I'll be replacing all the lines and fittings this weekend, but I didn't know whether or not I should use teflon tape to get a better seal on the threads. Theoretically if the flanges on the nipples are good, no gas should ever touch the threads, but I don't wanna do something stupid here.
Your thoughts are appreciated,
Stormin!
'54 Tiger T-110 (stock)
'04 Thruxton 900 (Staintune's, Hagon's, K&N Air, No A/I, 115/42 Jets, BT021 Radials (110/80, 150/70), 19 Tooth)
My Photo Album
Stormin is offline   Reply With Quote
Old 06-23-2006, 09:07 AM   #2 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Stormin,
You're right, if the flanges on the petcock and the pipe are in good condition, and the nut is done up snug, they won't leak. If the petcock starts to turn when you tighten the nut, use a 5/8" or 3/4" open ended spanner to hold the petcock centre tube straight. That way it won't turn in the tank against the lock nut, and snap apart the petcock thread (inside the tank hole). Don't ask.....
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 06-24-2006, 02:56 AM   #3 (permalink)
Favourite Bike: The 4 I Own
Other Motorcycle: 1977 Bonneville
Extra Motorcycle: '05 Rocket lll
I use the teflon tape (have been for years) and it seems to work just fine ! No leaks. Easy on, Easy off. Anything else? :-D
...and the Rocket's red glare
The jig is up.
The news is out.
They finally found me!
Styx... (Renegade)
Ride each ride like it may be your Last!
TRI-AL is offline   Reply With Quote
Old 06-25-2006, 07:21 AM   #4 (permalink)
ihave bought from my local dealer washers with rubber in the inside cercle(?).perfect ,no need for teflon
ben
when i ride i\'m always 17
peintremondain is offline   Reply With Quote
Leaking Fuel Fittings mebekj Speed Triple Forum 2 04-23-2007 07:32 PM
Fuel Fittings kuhlka Speed Triple Forum 3 07-25-2006 06:54 PM
Fuel Line Fittings tcowjww Tiger Workshop (archive) 10 02-01-2006 09:52 AM
Fuel Fittings? MeshMan Triumph SuperSports 3 07-15-2005 03:13 PM
New fuel fittings leaking? robadele Sprint Forum 21 05-29-2005 11:12 AM
