horn & wiring - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGearOntario TourismNew BonnevilleMotorcycle.com Classifieds!
Old 06-17-2006, 04:14 PM   #1 (permalink)
i had my thumb-switches apart the other day, and the plastic frame that held the horn switch (right hand, upper switch, purple wire) broke from age and dryrot.
i thought i'd be clever and switch the horn and hi-beam flasher wire (right-hand, lower switch, blue/white wire).
that makes the horn work, but unfortunately it also makes the horn work INSTEAD of my lo-beam.
i thought about hooking up what seems to be a kill switch red/white wire (left-hand, upper switch) to the purple wire that goes into the horn. that would seem to work, EXCEPT -- that if the red/white wire is a kill switch, it's supposed to be a "contact breaker" and i'm not sure if a "contact breaker" is the same thing as a switch.
there was another switch below the kill switch on the left-hand side, but i'm not sure what it does.
any suggestions?
basically looking for a workaround with the pieces i have. if that's possible, lemme know.
Sic semper tyrannis
johnnypence is offline   Reply With Quote
Old 06-17-2006, 07:33 PM   #2 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Johnnypence,
Don't know if your wiring is standard or not, or what has been done to the wiring in the past, but the Blue/White wire should not affect low beam. Did you connect the purple/black for the horn in the RHS Switch to the other switch, and disconnect the blue/white from that same switch? or did you cut the blue/white wire in the headshell and connect it to the purple/black wire going to the horn?
Before you go too much further, may I suggest you check the low beam (blue/red) wiring for an open circuit - you may have inadvertantly knocked something....
Pete
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 06-17-2006, 09:27 PM   #3 (permalink)
For what its worth, my headlight switch went bonkers and as thats expensive on mine, I by-passed the switch and have it on High all the time, 45 watts, wow. I disconnected the low beam all together. No body flashing me at night so all is well. If I decide to spend the dough, JVC has exact replicas with modern internals for both sides of a '79 model ,with lever( black). That's where I,m at for now. Running like a race bike should. Got that little rocker shaft leak. The famous pushrod leak I had stopped after I replaced the OPR.
okiecityflash is offline   Reply With Quote
Old 06-18-2006, 08:06 AM   #4 (permalink)
thanks for both suggestions. i only switched the blue/(i thought it was white) and purple/black wires on the switch, nothing in the headlight. although i have had plenty of occasions to be in the headlight and harness the past few days. i'm willing to work on it a little more.
but flash, again, i like the way you think: until somebody tells you to stop, there's nothing wrong with it.
[ This message was edited by: johnnypence on 2006-06-18 06:30 ]
Sic semper tyrannis
Old 06-18-2006, 09:37 AM   #5 (permalink)
Johnny, dont know if it will help, but check this out.poster size wiring diagram for your bike!
http://www.britishspares.com/122.php[addsig]
bleeding on it makes it work better
tinhead is offline   Reply With Quote
Horn Rainmaker Twins Technical Talk 12 09-07-2007 06:44 PM
Horn Wiring Circuit PriorityOne The Rocket Science Forum 1 03-28-2007 08:16 AM
I`ve really got the Horn... welshrob Sprint Forum 5 11-08-2006 08:16 AM
Better Horn on 03 ST Paul-K Sprint Forum 11 11-29-2005 06:02 PM
New horn 00wabbit Hinckley Classic Triples 1 11-16-2004 03:33 AM
