how hard to install a boyer ignition? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 18 (permalink) Old 06-04-2004, 07:56 AM Thread Starter
cat
Main Motorcycle: '13 Rocket Touring
cat's Avatar
Other Motorcycle: LTD 1000
Extra Motorcycle: bsa 650 lightning
i've been messing w/ points and timing for a few days and have been thinking of installing a boyer ignition. what are the performance benifits? how much wiring is involved? will i need new coils? this is for a bsa 650 lightning...
thanks,
cat
cat
George: Oh, oh I've got a helmet! I got a beauty!
cat is offline
post #2 of 18 (permalink) Old 06-04-2004, 08:40 AM
Slinky's Avatar
Extra Motorcycle: I wish
it's pretty straightforward really. This will give you a good idea.
http://www.pearsies.btinternet.co.uk...structions.doc
Don't do what I did and forget to disconnect the condensors- that caused a lot of headscratching.
Slinky is online now
post #3 of 18 (permalink) Old 08-17-2004, 05:23 AM
Main Motorcycle: The 3 I Own
Other Motorcycle: 1977 Bonneville
Extra Motorcycle: '05 Rocket lll
If you haven't already done it, DO IT! I did it & it was easy! The only trick is the timing with a strobe. Otherwise pretty straight-forward. They say you can use the 12 volt coils. I changed mine anyway to old Lucas 6 volts from a swap meet. They work. No real noticeable difference !
...and the Rocket's red glare
The jig is up.
The news is out.
They finally found me!
Styx... (Renegade)
Ride each ride like it may be your Last!
TRI-AL is offline
post #4 of 18 (permalink) Old 08-17-2004, 02:06 PM
Main Motorcycle: 1978 Triumph Tiger 750
hobbit's Avatar
Other Motorcycle: XLH883C Sportster
Seconded - best mod I ever made, worth every penny.
Amazing things indicators . . . pity yours don't work.
http://www.aavmcc.com
http://www.shinbukankendo.com
hobbit is offline
post #5 of 18 (permalink) Old 08-17-2004, 02:40 PM
ooobaby's Avatar
Put one in my '70 Bonnie......much, much better! P.S. Cat, look at my recent post on your previous Marne Iowa rally topic and let me know. Thanks! Jeff :-D Oh yeah, according to Baxter the Boyer Ignitions work better with the 6 volt coils. You'll have to ask him. The only thing I know about things electrical is that it's good for vaporizing screwdrivers. :razz:
[ This message was edited by: ooobaby on 2004-08-17 12:43 ]
ooobaby is offline
post #6 of 18 (permalink) Old 08-18-2004, 11:34 AM
They're godly, aren't they? PUt it on my 64, and first kick and it started. Hadn't run in 21 YEARS and it went first kick. Ignition was the difference. Kyle
post #7 of 18 (permalink) Old 08-19-2004, 11:13 AM
Have to agree Best 100 bucks you spend for a brit twin. Playing with the points , cond, advance weights is a thing of the past. Also might add I used a double ended Harley coil. Ithink the most important thing about coils is res . It has to be more than 3 ohms
Flatrack is offline
post #8 of 18 (permalink) Old 08-19-2004, 11:13 AM
Flatrack is offline
post #9 of 18 (permalink) Old 08-20-2004, 02:08 PM
I'm sorry to say, I never had the fun of messing with points, weights, and condensors. Needless to say, the condensors kept my bike from running. Boyers are magic. Install, kick, it runs. Right like that. Kyle
post #10 of 18 (permalink) Old 08-20-2004, 05:44 PM
I believe that you want 3-4ohms total resistance for both coils.
I'm running with 4.2ohms and it works, but the instructions from boyer say 3ohm/6 volt for high compression.
Boyer ignition question stu Classic, Vintage & Veteran 2 01-20-2008 10:28 PM
Should I install a Boyer ignition on my Bonneville? mailman Classic, Vintage & Veteran 38 01-31-2007 11:02 PM
Boyer Ignition Troubleshoot dagboy Air Cooled Twins Technical Talk 1 10-02-2006 02:52 AM
Boyer Ignition Klicker Classic, Vintage & Veteran 2 08-06-2006 05:59 PM
boyer ignition help please Classic, Vintage & Veteran 3 04-25-2003 03:54 AM
