BikeBandit
Old 05-06-2006   #1 (permalink)
Is it possible to fit a front brake light switch to the cable?
dorkingbonny is offline   Reply With Quote
Old 05-06-2006   #2 (permalink)
i believe the front brake cable has a brake light switch built inn ...my bonnie does (72)....tom
Ward...dontcha think you were a little hard on "the beaver "last night!!!
tnsen is offline   Reply With Quote
Old 05-06-2006   #3 (permalink)
yuo can find the suitable cable including the switch i think and install it according you make the circuit(electrical).the switch of a 71 or later will do the job; it's placed on the cable!
it's an easy diy job.
ben
when i ride i\'m always 17
peintremondain is offline   Reply With Quote
Old 05-07-2006   #4 (permalink)
1970 US T120'S came with a brake lite switch in the cable.
Most replacements currently come with the switch.
KADUTZ is offline   Reply With Quote
Old 05-07-2006   #5 (permalink)
Favorite Bike: 95 Thunderbird; 96 Sprint
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Hi,
This link may be of interest? Sparx
I see Carl Rosner are local dealers for Sparx, and it may be worth going along to S. Croydon for a chat? Not a bad ride from Dorking.
Ciao,
Geoff
:wink:
GeoffE is offline   Reply With Quote
Old 05-07-2006   #6 (permalink)
Thanks guys - I'll geta cable with a switch.
The one I have also needs the handlebar adjuster screwed right out - nowhere to adjust the cable further down - am I correct?
Old 05-07-2006   #7 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
The correct cable should have and adjuster built into it, usually down below the brake light switch. After setting that one up, use the one on the handlebar.
Hope this helps: Jim
Jim Ballard
jimballard is offline   Reply With Quote
brake light switch djw T3 Sport / Touring Forum 1 08-14-2007 06:26 PM
Front Brake Light Switch Went TeeBird Twins Technical Talk 2 09-01-2006 12:23 PM
Front Brake Light Switch Problem ibahillbilly Twins Talk 1 03-27-2006 02:10 PM
Brake Light Switch sllim Classic, Vintage & Veteran 2 10-31-2005 02:07 AM
brake light switch? Tumbleweed Classic, Vintage & Veteran 3 05-01-2004 08:04 AM
