First Triumph. I have a '73 T140 that looks and runs good but the clutch seems like it needs more lever. I've checked the plates and they're all about .143-.145" but very spongy. I've adjusted the pushrod adjuster so there's only a very slight delay in pushing the pressure plate and then adjusted the lever for very little slack. With the clutch all the way in, it pulls forward in gear. With the clutch all the way out, it finally doesn't slip. Best guess, cable stretchy, friction spongy, pressure plate flex or not square?
I noticed two odd things, when I put the pressure plate back on, no amount of adjusting the spring adjustment nuts would keep it from lifting off camber and I put new springs in it. The other thing is that I don't think any oil flows through the primary case, what little was there (maybe 2-3oz) was very milky although the oil in the reservoir is nice and black. How much should flow through the primary, how much should spill out when removing the case? What should I be checking?
