one pushrod not moving? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 04-27-2006, 02:44 PM Thread Starter
i was riding today and then all of the sudden one of the valves started making alot of noise then it stopped and the bike started running on one cylinder.
i got the bike home and took off the valve covers. the intake rocker on the left side isnt moving when i turn the engine over. so i look further and the pushrod does not move up or down with the motor.
what could cause this?
why me jesus?
internetay is offline
post #2 of 16 (permalink) Old 04-27-2006, 05:15 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
Possibly jumped off the lifter? Try to pick it up and put it back on in the center of the tube. Far fetched, I know but it's the simplest thing to do. You may have broken the camshaft or had the lobe go bad. Again, kind of far out but.... Also, the pushrod could be broken; using a box wrench, depress the valve and remove the pushrod. Hopefully, whatever it is will be minor.
Dreamin', I'm always dreamin': Jim
P.S. "Why me Jesus?"....when you find out, please let me know!!
Jim Ballard
jimballard is online now
post #3 of 16 (permalink) Old 04-27-2006, 07:03 PM Thread Starter
the pushrod is not in contact with the rocker arm as i can move the rocker as far down as the valve and high enough to where it hits the rocker housing, so it definatley is not in contact with the pushrod. i cant really see but i think the pushrod is lower than it should be being that i can move the rocker so freely up and down.
i would need to remove the rocker covers to get to the pushrod. so i guess that is the next logical step.
post #4 of 16 (permalink) Old 04-27-2006, 07:49 PM
I noticed this post is an hour later than your post on the tickler peeing on you. With the intake valve not opening while limping home, is the manifold flooded and pouring back to the carburetor? Might be why. Hope your pushrod problem is an easy cheap fix. Let us know.
okiecityflash is offline
post #5 of 16 (permalink) Old 04-27-2006, 10:31 PM
Legend
Could also be a broken rocker.
No matter what, your rockerbox needs to come off for a look-see.
You asked "Jesus, why me?" Because it was ME for the longest time, now it's somebody else's turn!
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is offline
post #6 of 16 (permalink) Old 04-27-2006, 11:31 PM
Main Motorcycle: T120RT
KADUTZ's Avatar
Other Motorcycle: T140V,T140D,T140E,T140J
time for me to go to bed
good nite mates! :
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is offline
post #7 of 16 (permalink) Old 04-28-2006, 12:48 AM
tridentt150v's Avatar
Could also be a valve seat dropped out [happenned to me once].
tridentt150v,
Great Southern Land.
tridentt150v is offline
post #8 of 16 (permalink) Old 04-28-2006, 12:52 AM
DAGAD's Avatar
Could be lots of things on that one cylinder, lets wait until the rocker box is off and then we should have some more info. As GPZ says 'it's gotta come off'.
Roy.
DAGAD is offline
post #9 of 16 (permalink) Old 04-28-2006, 08:37 AM Thread Starter
can anyone confirm that i have to take the gas tank off to remove the pushrod. i dont see any other way to get the rocker covers off.
post #10 of 16 (permalink) Old 04-28-2006, 02:41 PM Thread Starter
i took the rocker box off and alls that happened was the pushrod fell off of the tappet on the cam i repositioned it and turned the motor over and it moves! nothing looks remotely broken at all. so i need to order the gaskets adjust the valves and get it back together. thanks to everyone for their help.
i read somewhere that when you take the rocker covers off that it warps the head because the headbolts are incorporated into the cover. is this true?
Pushrod tubes........? GrayMitchell Classic, Vintage & Veteran 10 05-31-2007 03:08 PM
pushrod oil leak 71 TR6 tahoemojo Classic, Vintage & Veteran 3 05-28-2006 11:20 PM
Pushrod Seal failing twice? salamander Maintenance & Workshop Talk 4 09-16-2005 06:59 AM
popping pushrod seals veggiman Classic, Vintage & Veteran 0 10-22-2004 09:31 PM
pushrod tube "gushers" tnsen Maintenance & Workshop Talk 1 01-26-2003 01:12 PM
