Old 04-23-2006   #1 (permalink)
This loud clanging sound going into 3rd only happened rarely & now it happens all the time. It only happened for 1st once & never for the other gears. I adjusted the clutch at the handlebar lever & now not much slack left. Clutch does drag when stopped but I am assuming this is normal & always shift into neutral when at a light.
I've owned the bike for one month... my first Triumph.
This clanging can't be a good thing. I appreciate you sharing your experience.
Many thanks,
GulfCoastDave
GulfCoastDave is offline   Reply With Quote
Old 04-23-2006   #2 (permalink)
DAGAD's Avatar
Adjust the rear chain....................... it's clanging on the guard when it throws slack between changes.
Roy.
Loud 'Crack' Sound When I Start the 79 Tiger DavidGeorge Classic, Vintage & Veteran 9 07-21-2007 08:19 PM
Clanking Sound after Up or Down Shifting from Shaft BlueElf The Rocket Science Forum 3 12-02-2006 01:18 AM
Pipes are loud but look good and sound right too... Casper Twins Talk 6 05-24-2006 07:07 AM
Loud clanging sound...T140 GulfCoastDave Classic, Vintage & Veteran 1 05-18-2006 11:59 AM
slip on's that aren't loud but sound good and add HP/torque? dazco Twins Talk 5 06-30-2005 03:40 PM
