carboned plugs - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-18-2006, 09:54 PM   #1 (permalink)
Favourite Bike: 1959 Triumph Trophy 650
Other Motorcycle: yamaha silverado 1100
I posted a while back about the jets in the single carb 650 1959 monobloc. I went back to the specs with the settings and jets.
My book calls for a Champion N4 is that a hotter plug than a N3 or B8ES? I have an N3 & B8ES in it & regular unleaded in it now and it runs good, justs fouls the plug after sitting. Probably oil from worn guides.
Anyway, someone said that we cannot get a good looking plug burn on todays unleaded feul. Is that true?
The mag was rbuilt by Hunts Magneto. I have lowered the compression & retarded the spark a few degrees. This bike starts, idles and runs good. No pinking
Any thoughts on the N4s?
red59 is offline   Reply With Quote
Old 04-18-2006, 10:10 PM   #2 (permalink)
Favourite Bike: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
N4 is one step hotter than N3. Sorry I dont have an NGK Chart handy. MAYBE just MAYBE your idle adjustment is a tad rich
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is offline   Reply With Quote
Old 04-18-2006, 10:55 PM   #3 (permalink)
I always thought the higher the number the colder the plug. Am I wrong?
okiecityflash is offline   Reply With Quote
Old 04-18-2006, 11:57 PM   #4 (permalink)
Ifin I be memberin correct JAP plugs are opposite of champions
TRIUMPH
Old 04-19-2006, 01:00 AM   #5 (permalink)
Man, at my age and I'm still learning something new every day. Figures tho' japs
Old 04-19-2006, 01:26 AM   #6 (permalink)
Running a cold plug will cause fouling. I use to run a hotter plug in my marginal engines to keep them from fouling but it does decrease the life of the plug. If it is oil fouling you should see blue smoke out the exhaust. If it burns off and then stops it is probably your valve guides. If it get worse as it warms up it is probably rings. Also check plug wires. I almost always replace plug wires on used vehicles if they are older than about 10 years. Has cured an amazing number of carb and ignition problems.
Plugs? webonnielad Twins Technical Talk 1 01-26-2007 03:33 PM
Will I need new plugs? skrap1r0n Sprint Forum 5 03-09-2006 09:28 PM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 11:54 AM
plugs musicman59 Classic, Vintage & Veteran 8 09-19-2005 12:02 PM
Plugs Pharmaboy Sprint Forum 2 06-03-2004 03:24 AM
