| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
04-18-2006, 01:04 PM
Posts: 112 Other Motorcycle: KZ1000, CL450, TC100
I have a new patent plate to install. How did you guys get the old one off? I was thinking of sliding a putty knife behind the plate and prying it off but i don't want to scratch the case. Any tricks or tips? 73 Bonnie. Thanks
04-18-2006, 04:26 PM
Supersport 600 Favourite Bike: 1978 Triumph Tiger 750
Posts: 182 Other Motorcycle: XLH883C Sportster
I used a small cold chisel to cut off the rivet heads, then drilled them out to create the holes for the rivets to fix the new one on with . . . if you're binning the old plate, it doesn't matter if it gets damaged, and it stops any damage to the cover, although if you're putting a new plate on, it would hide any scratches on the timing cover anyway . . .
04-18-2006, 06:08 PM
Use a dremel hand tool and a cutting disc. Put a slot in the head of each rivet and then using a small screwdriver unscrew the rivets. They are a twist rivet, so will screw out OK. If you have the cover off, I'd also recommend popping the cover into the family oven at low for a while to warm the case up before you begin screwing the rivets out.
tridentt150v,
Great Southern Land.
04-18-2006, 08:04 PM
World SuperBike Favourite Bike: 2002 Triumph Trophy
Posts: 2,040 Other Motorcycle: 1970 Triumph Tiger 650 Extra Motorcycle: 1999 Yamaha Virago 1100
I carefully pried the plate away from the rivets and was able to grab them with small vice-grips; then I pulled and twisted as if it were a screw, and out they came. I got this method from John Healy of Coventry Spares. He's been a Triumph "guru" for many a year.
Hope this helps: Jim
Jim Ballard
04-18-2006, 09:40 PM
All good suggestions. Just make sure you twist gently. They are actually spiral nails. And the heads can pop off if you twist too aggressivly, leaving the shank in the cover. Some come right out others may be really tight. Put some layers of durable tape around the plate so there's no risk of scratching/gouging the cover. Do everything "easy". Think "fine jewelry".... :hammer:
"I Live In My World, And I Am My Own King In My World, Whether It Be A Garbage Dump, Or In The Desert Or Wherever It Be".........Charles Manson
04-19-2006, 09:03 AM
SuperSport Favourite Bike: 1970 TR6 Spring Gold!
Jim is on the money. I removed mine a few months ago. The nails are spiral. If you gently pry the old plate off, the nails will remain in the case. Twist the nails counter-clockwise with some pliers and they should come out very easily. Or at least mine did. Then just tap the new ones in and your good to go.
Hey, What's this oil on the floor?
04-19-2006, 09:44 AM
Site Supporter SOTP Vintage Series Favourite Bike: '67 Triumph Bonneville
Posts: 7,674 Other Motorcycle: British Iron Extra Motorcycle: Dreer Norton Prototype
I have found it best to remove the old plate in the manner described above BEFORE trying to remove the tap-in "screws". That way, you have the advantage of the slight gap and protrusion of the screw head after the plate is out of the way.
04-02-2009, 07:29 AM
So if you do break them off you just drill the remainder out and re-install?
I have broken only one of the rivets and can't get ahold of the others to remove them.
BTW I was told to twist them clockwise, not counter clockwise. Which is correct??
TIA,
TD
04-02-2009, 10:24 AM
COUNTER-clockwise.
If you can get the other two out, re-install using those two, then drill for the third at a VERY slight angle off the broken one, so that you stay within the casting on the backside; else you might create an oil leak!
04-02-2009, 10:37 AM
Originally Posted by GrandPaulZ
COUNTER-clockwise.
Thanks GP.
Will try.
TD
