Rear Chain Adjustment - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Ontario TourismMotorcycle.com
Old 04-16-2006, 07:54 AM   #1 (permalink)
What is the easiest way to check rear wheel alighnment - my tyres are not the same width?
I would really like to put parallel marks on the slot where the rear wheel spindle fits in the long run
Thanks for any help - I want to get riding in now after a long rebuild
dorkingbonny is offline   Reply With Quote
Old 04-16-2006, 03:09 PM   #2 (permalink)
I usually just eyeball the rear chain from sprocket to sprocket. Not very scientific. I've heard there's a tool that clamps on to the rear sprocket with a sight on it that you line up on the drive sprocket. Sounds dandy. I believe a guy could make something like it fairly easy. You can use 2 straight edges on the back tire and get the same distance from the front tire on each side. 2 straight studs would work, but you have to have the handlebars absolutely straight. Maybe a laser type rule. :???: Oh yeah, I also measure the chain adjusters on mine, making sure first the little adjuster plates are both flat and not bent. I think you could measure or count threads on yours. Make any sense. Let us know what you find best, OK :???:
[ This message was edited by: okiecityflash on 2006-04-16 13:23 ]
okiecityflash is offline   Reply With Quote
Old 04-18-2006, 11:00 PM   #3 (permalink)
I posted a lenghty reply under the topic "Wheel adjustment" about the straightedge clamp I devised. One lightweight steel angle each side of the bike, clamped to the rear wheel with two long bolts, spacers each side of front tire, then adjust wheel and tighten axle nut. Angles force the wheel to stay aligned perfectly as you adjust.
Gale Gorman
Houston
Gale_Gorman is offline   Reply With Quote
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 12 06-17-2010 05:30 PM
First Chain Adjustment drharveys Twins Technical Talk 15 03-06-2008 04:44 PM
chain adjustment britironrider Twins Technical Talk 5 01-21-2008 12:47 AM
Chain Adjustment boocat Tiger Workshop (archive) 3 05-17-2007 09:35 AM
Rear Chain Adjustment dorkingbonny Classic, Vintage & Veteran 8 11-11-2005 02:55 AM
