Bonnie wiring question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-11-2006, 07:23 PM   #1 (permalink)
Other Motorcycle: KZ1000, CL450, TC100
73 Bonnie T140V. New owner and not sure if the prior owner has the wiring right. I just want to make sure before I hook the battery up. I looked at the wiring schematic but still have some questions. Here is what I have
Sitting on the bike
Left coil- black/white, white/yellow
Left condensor- black/white going to left coil
Right coil- white/yellow, black/yellow
Right cond- black/yellow going to right coil
Rectifier- red, green/yellow, 2 brown/blue one of the wires
has been cut and a fuse has been added but it is missing the connection for it
Red wire (ground?)
Also has a brown/blue wire with a 35amp fuse and two eye connections but neither are connected to anything
How does everything look so far? What connects to the positive batt terminal. Where does the loose brown/blue wire with a fuse connect to? Can you start the bike with no battery? I am new to the Lucas system. Thanks
kawtoy is offline   Reply With Quote
Old 04-11-2006, 08:03 PM   #2 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
Kawtoy,
Coil/condenser wiring is correct if you have points fitted.
Rectifier - Red is centre connector on top (earthed through centre bolt). Two wires (I think they were green/white, green/yellow) come from the alternator, Brown blue should be Negative to battery, via the fuse.
Red is ground (battery positive).
Bit hard without a diagram, but here goes....
Batt -ve ----- 20A Fuse -----Rectifier, Zener, Ign Switch, possibly headlight switch. Brown/blue wires.
Batt +ve ------ Rectifier, earth on Engine, also may be earthed under Zener mount (not sure on 73). Red wires.
Need the battery, and in good condition, to start
Pete
[ This message was edited by: OzBloke on 2006-04-11 18:04 ]
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 04-11-2006, 08:27 PM   #3 (permalink)
Just found out the importance of the battery. Got a new one today it started on the second kick...after 20 years. Thanks
67 bonnie wiring problems jackson Twins Technical Talk 8 07-21-2007 11:22 AM
77 bonnie handlebar switchgear wiring question meatwagon Classic, Vintage & Veteran 4 03-26-2007 12:29 AM
'69 Bonnie wiring beegee Classic, Vintage & Veteran 2 09-17-2005 10:24 PM
72 bonnie wiring problems buggy Classic, Vintage & Veteran 3 07-23-2004 04:28 PM
wiring 76 bonnie Classic, Vintage & Veteran 4 04-14-2004 09:05 AM
