Has anyone upgraded to the high capacity OEM oil pump? It consists of Oil pump #71-7317, Oil pump gasket #71-3910, Allen bolt14-7008, and Allen bolt 14-7007. The pump itself is only about 20 bucks more than the stock pump. Has 4 valves instead of 2. Seems pretty simple installation, except a clearance problem with the timing cover. Must grind a little off the cover for correct cover seating, or buy another cover. I think these were factory upgrades in late'79 or early '80. If anyone has done this I'd appreciate if you would share any experience., pro or con.
[ This message was edited by: okiecityflash on 2006-04-02 01:33 ]
