engine assembly tool - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-31-2006, 10:17 PM   #1 (permalink)
CDBonne
Greetings
My service manual refers to a tool
bolted atop the cylinder used to hold
the crankshaft for assembly purposes.
Unfortunately I have no pictures.
Is this something one could make with some aluminum stock?
It must sit below TDC eh?
I would appreciate any references or more info,
Thanks
Chuck
Old 04-01-2006, 09:55 AM   #2 (permalink)
Favourite Bike: '67 Triumph Bonneville
It's a hollow, shouldered bolt that screws in just behind the base of the cylinders. A small pin (with a safety stop) drops down though it and falls into a notch that is cut in the crankshaft. The crank has several notches, so you must first get it close to the correct one, then wiggle it 'till the pin drops into place.
Easy thing to do is order a replacement bolt, drill a 1/8" hole dead-center through the bolt, and use a long drill bit to drop in.
OR - BUY THE TOOL!
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 04-01-2006, 10:47 AM   #3 (permalink)
CDBonne
Thanks GPaul
I have tool D571 but my literature titled
"Overhaul manual for 650 unit construction triumph motorcycle
engines since 1963"
By Thomas G. Gunn,jr
Truimph corp. Nov.20, 1967
on page 3 says use CD474 engine locking tool on the cylinder barrel and NOT to use D571/2t tdc in flywheel.
What is CD474?
I appreciate any response.
Chuck
Old 04-01-2006, 07:04 PM   #4 (permalink)
Favourite Bike: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
Just as reference point the manual referred to was given to
mechanics at the TRI-COR Mechanics Training Center.
It is 18 pages long typed on normal 8.5"x11" paper with no pictures or illustrations.
Tool CD474 consists of 4 parts and is refferd to on page 3 (disassembly) and page 11 (assembly) of this document.
CD474
aluminum block 1"x1"x7 1/8" (Qty 1)
this block has 2 holes (approx 17/32') drilled all the way thur on approx 6 1/2'' centers. It is designed to bolt down to the top of cylinder block using the front outside bolt hole and the rear outside bolt hole in a diagonal manner.
bolt 3/8''(26)x1 5/8" (Qty 2) same as a head bolt but shorter
flat washer 3/8'' (Qty 2)
metal dowel rod (Qty 1) approx same diameter as piston pin and 4 1/2'' long
I would assume you shouldn't use the timing tool as an
engine lock because crank leverage on the tool could fracture the case.
[ This message was edited by: KADUTZ on 2006-04-01 20:16 ]
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is offline   Reply With Quote
Old 04-01-2006, 08:08 PM   #5 (permalink)
I've never heard of that tool, only the one shown in the Triumph , Haynes & Clymer manuals as I described...
GrandPaulZ
Born Again Bikes
My Photo album
Old 04-05-2006, 11:52 AM   #6 (permalink)
donnydildo
use a small socket (3/8'')and put an 8 mm.drill in it, so you can find this hole in the crankshaft.
Old 04-05-2006, 04:44 PM   #7 (permalink)
S---t K!!. You never cease to amaze me. You other pro"s too. :yayyy: I don't think I ever knew as much about anything, except partying
[ This message was edited by: okiecityflash on 2006-04-05 14:48 ]
okiecityflash is offline   Reply With Quote
Old 04-05-2006, 11:41 PM   #8 (permalink)
Why did you have to censor the word SHOOT?
Hey what do you call the Texan that worked
on Kawasakis?
A Kawboy!
I know but you thought tht Monty Python SPAM skit was funny right?
TRIUMPH
Old 04-06-2006, 07:05 AM   #9 (permalink)
K! You are very observant. Hope I spelled that right. Difficult for guy that doesn't remember how many letters***** has. Guess it happens. All kidding aside, thanks for sharing your expertise. Have a good one.Thanks
Old 04-08-2006, 09:05 AM   #10 (permalink)
CDBonne
Thanks KADUTZ
I think I get how the bar stops the pistons Before TDC.
In another place in the instructions, before the barrels are set,
The wrist pin diameter bar would go between the rods above the
square stock bolted(?) to the top of the case.
Chuck
Headlight Assembly chip0704 Sprint Forum 3 09-04-2007 11:34 PM
Clutch assembly Limey Speed Triple Forum 10 08-08-2007 07:47 PM
assembly order help Hughdemann Classic, Vintage & Veteran 7 03-04-2007 03:32 PM
Tool for cleaning engine deck ? Normandy Twins Talk 5 06-13-2006 04:05 PM
Tool Talk: Spark Gap Tool Preference? 00wabbit Maintenance & Workshop Talk 6 01-15-2005 03:02 PM
