amal carb pilot-circuit mod - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-30-2006, 09:41 AM   #1 (permalink)
so last night i performed my first carb-rebuild on my '71 T120R and as i was following the clymer manual i found it odd that both of my carbs were completely lacking pilot jets. then i noticed that the intake hole for the pilot circuit was blocked by some sort of machined plug. here is a crappy cell-phone picture:
could you guys enlighten me or point me to some discussion of this type of carb modification? what do you gain and what do you lose with this mod?
also i'm assuming this was done by two owners ago b/c the last person to do a carb rebuild put both pilot air screws in the left carb and both idle screws in the right carb. :???: fixing that combined with a cleaning greatly improved my starting/idle.
kanoa is offline   Reply With Quote
Old 03-30-2006, 06:55 PM   #2 (permalink)
Kanoa ,
The pilot jet was abolished mid 1968 .That plug is blocking the intake passage that is not used .If you compare the carb bodies you will see that one has the opposite hole plugged from the other.These are not modifications they are stock .
Lutz
Lutz is offline   Reply With Quote
Old 03-31-2006, 09:24 AM   #3 (permalink)
ha ha ok THANKS
Amal carb question... fightingzero Classic, Vintage & Veteran 14 11-22-2009 07:33 AM
76 T140- Amal Carb jetting question glw Classic, Vintage & Veteran 6 01-01-2008 07:19 PM
amal concentric carb. main jet size ? alcide Classic, Vintage & Veteran 2 05-16-2007 03:34 PM
Amal carb swap flyrodder Classic, Vintage & Veteran 1 08-04-2006 02:29 AM
626 amal carb issues Classic, Vintage & Veteran 4 09-21-2004 09:18 PM
