Leak proof fork seals - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports Ontario TourismSportbikeTrackGear
Old 03-29-2006, 06:32 AM   #1 (permalink)
Favourite Bike: 1971 TR6R Triumph Tiger
johnquinnell's Avatar
Other Motorcycle: 2006 Triumph America 790
Have any readers had better luck with Leak Proof Fork Seals over the orignial OEM seals?
http://www.britcycle.com/Products/le...fork_seals.htm
I have a '71 OIF 650 Tiger and despite correct installation and good surfaces on my tubes, the brand new OEM seals leaked as soon as I went for my first ride after fitting them.
I'm even thinking about talking to a bearing supplier about double lipped oil seals for bearings that might be able to do a better job but if the leak proof brand come recommended I'd be prepared to try them first?
johnquinnell is offline   Reply With Quote
Old 03-29-2006, 07:30 PM   #2 (permalink)
johnquinnell
I strongly recommend using Leak Proof seals but be sure to use the retainer from a later model T140. Part # 97-7016
especially on 1971 and 1972 models .Do not use the retainer furnished with the seals because they do not fit tight and will come loose and the seal will come out of the slider.
Lutz
Lutz is offline   Reply With Quote
Old 03-30-2006, 12:48 AM   #3 (permalink)
Thanks for the feedback Lutz. Nothing like a personal recommendation for aftermarket parts used by fellow riders. Now all I have to do is sort out my anotomical seat padding issue and I guess I'll find utopia..... :wink:
[ This message was edited by: johnquinnell on 2006-03-29 22:49 ]
Anyone has tried these fork seals? powerdarko Hinckley Classic Triples 5 01-07-2008 09:59 AM
Has anyone used these fork seals? chrismatthewsmm Hinckley Classic Triples 1 12-13-2007 02:43 PM
Fork Seals Mercury264 Speed Triple Forum 1 04-19-2006 10:09 PM
Fork seals Trophy 8 01-26-2005 09:32 AM
oil leak , seals , front sprocket durkster Hinckley Classic Triples 2 01-13-2005 01:09 PM
