78 T-140E Oil Pressure gauge question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-27-2006, 10:47 AM   #1 (permalink)
Just got this beauty about a week ago and have not had a bike for many years, so please make allowances for what may seem really dumb questions from this Pilgrim. I have a Haynes book but no owners manual so I'm missing some really basic information.
1. Am I correct in assuming that the red light on the headlight is the oil pressure warning light?
2. Can an actual gauge also be installed? Where can one be obtained?
Many Thanks,
GulfCoastDave
GulfCoastDave is offline   Reply With Quote
Old 03-27-2006, 12:42 PM   #2 (permalink)
Favourite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
Check the Oil Pressure thread in this column. It should cover your needs. Wish I could tell you and Oki where to find a gauge, though. Also, read the thread on Hoses in this column.
Good Luck: Jim
[ This message was edited by: jimballard on 2006-03-27 10:44 ]
Jim Ballard
jimballard is offline   Reply With Quote
Old 03-27-2006, 12:59 PM   #3 (permalink)
DAGAD's Avatar
Check out the car breakers or the car custom shops. The pipe (hose) is easy to find.
Roy.
Old 03-27-2006, 04:07 PM   #4 (permalink)
Favourite Bike: '67 Triumph Bonneville
I thought the Red light was for "ignition on", but that may be older models only.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 03-27-2006, 08:55 PM   #5 (permalink)
Favourite Bike: 77 Bonneville
OzBloke's Avatar
On my 77:
red - oil pressure (LHS when seated)
orange - indicators (middle)
green - high beam (RHS when seated)
Per Ardua Ad Astra
OzBloke is offline   Reply With Quote
Old 03-27-2006, 11:31 PM   #6 (permalink)
Favourite Bike: T120RT
Other Motorcycle: T140V,T140D,T140E,T140J
No question is to dumb
(all references are to 2Cly models)
Warning lights
1 Red This is ign on light and oil pressure light
When the ign is turned on this will light up. When the engine is started it will go out. If it doesn't you have a problem.
2 Green This is your high beam light will only light up when high beam is in use.
3 Orange/Amber This is your turn signal indicator light used on 1971 and later models. Lights with indicators
4 Blue This is you neutral indicator light used on 1979 and later models Lights when trans is placed in neutral.
Oil pressure switch
There were two oil pressure switches used
1 Part no 60-2133(D2133) used up thru 1973 and used a
1/8 NPT for the thread
2 Part no 60-3719 used 1974 on my listing on this only says BSP for the thread.
Any oil pressure gauge can be used. I mounted mine from a home made bracket off gas tank strap bolt (right side) on my 78 T140V. The nylon line came in the package along with fittings and same threaded in to the timing cover (also use Teflon tape) gauge assy was purchased at Kmart or someplace like that. Not sure if you want to use a gauge for testing or mount one for" keeps"
also you might want to go to www.triumphbracket.com for ideas on mounting
als
[ This message was edited by: KADUTZ on 2006-03-27 22:18 ]
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is offline   Reply With Quote
Old 03-28-2006, 01:42 AM   #7 (permalink)
DAGAD's Avatar
Sorry to dissagree with you Kadutz but Triumph never used a NPT thread, it was BSP and parrallel. That is why there is ALWAYS a flat sealing washer listed. If you use NPT it will split the case out as it is tapered.
Roy.
Old 03-28-2006, 02:59 AM   #8 (permalink)
I've been looking for a TEST gauge. Never dawned on me any manual oil gauge wil serve my pupose. I remember I mounted one on a scooter in the past. Thanks for the imput. :blush:
okiecityflash is offline   Reply With Quote
Old 03-28-2006, 07:00 AM   #9 (permalink)
Roy
I could easily be wrong on the tread pitch on the early switch. I don't have one here to check. All my reference material lists says 1/8 NPT(or tapered) on the early switch and
BSP on the later switch.
As with everything if in doubt check check and triple check
and do not force anything
Have a nice day!
TRIUMPH
Old 03-28-2006, 09:21 PM   #10 (permalink)
Got and installed an oil gauge today. Drag Specialties. Not bad ,$37.50. Got it at the chopper shop. I posted the results on New Topic. Not good.
Oil Pressure Gauge install.... SCCTrim Twins Talk 26 04-28-2009 07:49 AM
My oil pressure gauge bonnevillebilly Twins Talk 8 05-08-2007 09:01 PM
oil pressure gauge cafecruzin Club Cafe' 1 03-03-2007 10:38 PM
New Bonneville Oil Pressure Gauge bsmith222 Twins Technical Talk 26 09-26-2006 03:46 PM
Oil Pressure Gauge bsmith222 Club Cafe' 2 09-25-2006 08:49 AM
