BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
Old 03-26-2006   #1 (permalink)
Anyone ever encounter more than one spacer under their engine sprocket during rebuild? It seems that upon reassembly, I wound up with an additional spacer, actually a washer that is the exact size-sans width- of the spacer. Neither the replacement parts catalog, nor the repair manual mention the part; however, the repair manual does state the following: "note the disposition of the rotor, engine sprocket and any spacer(s) fitted as an aid to correct assembly," implying that there could be more than one. I usually take good notes, but I obviously messed up and overlooked the "disposistion," and failed to account for the part. Any help would be appreciated greatly. Hank P.S. I am referring specifically to my 72' Daytona.
HankQ is offline   Reply With Quote
Old 03-27-2006   #2 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
Justblike the book says, could be one or more to properly align the chain.
Yuk! Yank the clutch back out...
If you don't do it now, for free, you'll do it later at a cost.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 03-27-2006   #3 (permalink)
Thanks GPZ, actually I did not have the clutch all the way in, just the engine sproccket, chain,and outer hub. I will however have to redo the 24 free floating roller bearings. No biggie though, I rather enjoyed that part. Hank
Old 03-27-2006   #4 (permalink)
Moderator
A litlte bearing grease makes that task a breeze.
GrandPaulZ
Born Again Bikes
My Photos
Polishing Your Engine Crank, Sprocket, and Clutch cover jkieler Twins Technical Talk 6 02-22-2007 12:14 PM
Torque specs needed for engine covers/sprocket cover Bob_N Twins Talk 2 05-02-2006 08:39 PM
Alternator - spacer vibration Spooner Hinckley Classic Triples 6 09-27-2005 12:30 PM
Leaking Oil From Engine Sprocket Cover. Avatar Hinckley Classic Triples 9 05-12-2005 10:37 AM
Help! Can somebody machine a spacer for me? MickMaguire Modifications & Workshop Talk 6 03-10-2005 08:33 AM
