While I agree with you guys, sometimes the shoulder bolts that the carb fits on are too short for the 1/4" thick fibre spacer. The thick 'o' ring SHOULD be fitted and you could try using a tufnell spacer from a Norton. I have these from 1/16" up to 5/32" and use the one to suit a full nut on the stud.
#New cups and rubber washers are cheap and easy, but as the advice says, DON'T overtighten. You should be able to move the carb when correctly fitted.......... only slightly when wiggling it.
Roy.
