Motorcycle.comBikeBanditAdvanstarMotorcycleShows
BikeBandit
Old 02-19-2006   #1 (permalink)
Britvat
I have a 1970 Triumph Trophy that I got years ago as a "basket case" I'm looking for a wiring diagram and a compatible electronic ignition.
Can anybody point me in the right direction?
Old 02-19-2006   #2 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
Your best bet would be to get a parts and repair manual (factory copies) from one of the many British suppliers. Hutchinson Cycles in Wakefield MA has them. They are invaluable.
Good luck with it: Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 02-19-2006   #3 (permalink)
If you have a fax number I will fax you a copy of the wiring diagram for a 70. Is your bike a TR6 os aTR6C?
As far as the ignition Boyer's are decent. I run points in my bikes except for my T140E and T140D that came with factory elec ign.
Also note if you are using a NOS Lucas loom there may be wires in the loom not shown in the diagram. turn signals weren't used in the US until '71 yet the correct wires were in the loom.
One question how did you get this far without some kind of a shop manual? Every one I have has a wiring digram.
KADUTZ is offline   Reply With Quote
Old 02-20-2006   #4 (permalink)
if you need to buy bits for your ignition system, you might want to consider this method...
keep to the original points and install the bmw system of a twin output coil. connected to one set ( do not connect the other set )
that way easier to time both cylinders exactly the same. if the points fail . Connect to the other set of points, although usually they fail slowly enough for you to not be needing roadside repair.
you can also get very cheap points based capacitor discharge system they use very little points current and can therefore expect 25k+ miles per set . the big thing here is, if the electronics fail, you can just change 3 spade connectors and run without. if the points fail, change one spade connector over. if u want more details email me or ask here.
A wise man learns from his mistakes..
A genius learns from other peoples mistakes.
panda is offline   Reply With Quote
Old 02-20-2006   #5 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
Diagram e-mailed.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
electronic ignition help. nate440 Modifications & Workshop Talk 1 09-18-2007 01:00 AM
Question re Electronic Ignition ohiorider Twins Talk 6 05-09-2006 12:39 AM
Wiring diagram and electronic ignition for 1970 trophy Britvat Modifications & Workshop Talk 1 02-19-2006 01:21 PM
Anyone have an ignition wiring diagram? Lowkee The Rocket Science Forum 4 10-26-2005 11:36 AM
6v electronic ignition COOPERS Classic, Vintage & Veteran 0 12-20-2004 05:46 PM
