Charging system upgrade. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-29-2006, 06:13 AM   #1 (permalink)
I am upgrading the charging system and need to know how many watt's or amps I need. I know how to figure all the lights and I wont be running any extras like heaters or sound systems, I will be running with the head light on all the time, but I dont know how much the ignition system draws. Which ignition system draws the most current, electronic or stock points? Any suggestions as to what I need?
jtrip is offline   Reply With Quote
Old 01-29-2006, 08:29 AM   #2 (permalink)
Any available modern alternator should be automatically matched to the old bike. There are only a half-handful available.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 01-29-2006, 08:30 AM   #3 (permalink)
On the 650 I assume?
When you say upgrade the charging system, you'll be looking at a 3 phase alternator stator, & a solid state regulator/rectifier like the PodTronic or Boyer units. As I understand it the original lucas ones were 180 watts (RM21) but I think there might be modern equivalents with an output of 210 watts, unfortunately I can't recall from where.
I'm not really sure what sort of current draw the ignition systems have, but any of the 3-phase units will have sufficient capacity for decent lighting & igniion. I don't know of any source for alternators of greater output than those I've mentioned , although I'm sure they could be custom made if funds were unlimited!.
regards
Cuppa
Cuppa500 is offline   Reply With Quote
Old 01-29-2006, 08:36 AM   #4 (permalink)
GrandPaulz,
You must have been typing your much more succinct & accurate reply at the same time as me. It's what I meant to say. It's late at night here (Downunder), that's my excuse & I'm sticking to it.
Regards
cuppa.
Old 01-31-2006, 07:13 PM   #5 (permalink)
vik
These are rumoured to be good and available worldwide :
Sparx
Triumph or Die
vik is offline   Reply With Quote
Charging system m970456 Speed Triple Forum 1 03-16-2007 10:25 PM
Charging System tyrebyter Tiger Workshop (archive) 0 06-30-2006 07:17 AM
Charging system. jtrip Classic, Vintage & Veteran 1 11-07-2005 10:56 AM
charging system help! Trophy 5 04-01-2005 01:18 PM
charging system Maintenance & Workshop Talk 2 03-30-2005 04:40 PM
