The engine number tells you it was from a T120, a 650cc Bonnevlle.
You could start a war over what engine oil to use , some people will say a straight 30, others may say a multigrade. A 20/50 should be okay seeing as you are in a warm climate.
Gearbox oil should be EP90.
A worn valve guide would cause oil burning, not a fuel leak... A fuel leak would be carb related, there was an earlier thread on this subject. The float or float needle would be the likely culprits.
Your best bet for a manual would be the Haynes manual, or maybe Clymer if they do one. Good luck with it..
