I used to do that with my '68 Trophy. ( i.e. tap the shaft out JUST ENOUGH to replace that O-ring, then slide it back in) BUT, on my '77, I took some Carb cleaner & sprayed it around the shaft, then some brake cleaner ( to try to remove as much oil as possible) then smeared a small amt. of silicone (RTV) sealant around the shaft with my finger. So far, so good! I never removed the old O-ring. It's holding! I used the black sealant. I suppose other colors are availabe, but it's such a small area, you don't even notice it! They make some good sealers nowadays. :hammer:
...and the Rocket's red glare
The jig is up.
The news is out.
They finally found me!
Styx... (Renegade)
Ride each ride like it may be your Last!
