clutch pushrod stuck? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGear
Old 12-19-2012, 09:12 PM   #1 (permalink)
Main Motorcycle: 76 T140
On my 76 T140, I am ready to use the clutch hub extractor tool but it seems that the clutch pushrod is stuck - can't pull it out.
The clutch is totally slack now. shouldn't it just slide out easily ?
Thanks
Dave
DaveDone is offline   Reply With Quote
Old 12-19-2012, 09:22 PM   #2 (permalink)
triumpt120rv's Avatar
This may or may not be the same problem you have. A small ridge of rust built up around the rod in the middle section causing the rod not to slide out. I attached a vice grip to the end and tapped out the rod. I sanded off the rust and it slid back in smoothly.
Old 12-19-2012, 09:31 PM   #3 (permalink)
Thanks triumpt120rv, I guess I'll try that. I don't see how any thing would get ruined by forcing it out.
Dave
Old 12-20-2012, 08:34 AM   #4 (permalink)
no luck with the vice grips and hammer- but I didn't wail on it.
seems like it's more than rust. I'll take the gearbox cover off and look at the bush on the other end.
Dave
Old 12-20-2012, 11:11 AM   #5 (permalink)
Main Motorcycle: T140 E
It's possible that the ks end is burred and it won't fit through the hole?
DAVE M is offline   Reply With Quote
Old 12-20-2012, 05:36 PM   #6 (permalink)
Thanks DAVE M -it was a burred end. I pulled of the outer trans case and was able to withdraw the clutch push rod from that side. It would not pull out from the driveside as it would not pull through the bushing ( 57-3988)
Now I wonder if the bush should just freely sit on the pushrod or is it suppose to be tight in the mainshaft end?
I guess I can grind the mushroom end of the pushrod back to smooth easy enough but why did it get that way? I don't see any unusual wear on the clutch lever shaft.
Thanks for any help here.
Dave
Old 12-21-2012, 06:46 AM   #7 (permalink)
the bush should stay in the engine.
Maybe a PO didn't harden the end?
You neat to file it, and temper? it
I think it's heated till cherry red and quenched in oil? check!
I'd measure it first incase it's now too short. You can cut it and add a ball bearing in the middle to add length, or order a new one
Fu?*!ng clutch pushrod seal Slinky Hinckley Classic Triples 33 09-01-2012 11:45 PM
Clutch pushrod material???? 68TR6R Classic, Vintage & Veteran 4 02-08-2010 01:37 PM
Clutch pushrod seal Nobeard T3 Sport / Touring Forum 3 07-22-2009 01:10 PM
Clutch pushrod; Is it reversable? pendraig T3 Sport / Touring Forum 4 08-27-2008 07:39 AM
BSA A65 clutch pushrod length?? TravThrux Classic, Vintage & Veteran 2 11-23-2006 07:21 AM
