conrod question - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 12-12-2012, 07:04 AM   #1 (permalink)
Main Motorcycle: 76 T140
conrod question
Should there be this much side to side play on the big ends? I don't have any movement up and down but there seems to be a lot of slop in the bearing?
There was hardly any side to side movement when the pistons were in the cylinder block but when I removed the barrels there is much play on what seems to be in the big end bearings. is there side to side play on the big ends? I don't have any movement up and down but there seems to be a lot of slop here. Could the connecting rod bolts be loose?
I just wanted to change my base gasket not intending to split the cases. The bike was running ok but now I am concerned.
Thanks for having a look.
Dave
DaveDone is offline   Reply With Quote
Old 12-12-2012, 07:25 AM   #2 (permalink)
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
No, the bolts cannot be loose, if the bike was running ok.
There is no spec or maximum for sideplay on big ends.
If you are worried, reassemble it as it is and check hot oil pressure.
Triton Thrasher is offline   Reply With Quote
Old 12-12-2012, 07:55 AM   #3 (permalink)
Main Motorcycle: 1970 Bonneville
How much side to side play is there? This will help those who know better than me to offer a considered opinion. I have read that 1mm would be OK.
henryanthony is offline   Reply With Quote
Old 12-12-2012, 09:53 AM   #4 (permalink)
Thanks !
As soon as I posted I saw the "Similar Threads" listed at the bottom of the page I have to remember to use the search function.
From an older post I see that I am just within Mr. Pete's specs - old post here.
Big relief !
Dave
Conrod play? loxx101 Classic, Vintage & Veteran 11 07-15-2012 03:00 PM
Question for about Triumph Twin Power Tune (Pieman Question) Shopshirt Twins Technical Talk 6 01-13-2012 09:35 PM
Conrod meltdown steve firth Classic, Vintage & Veteran 2 06-05-2009 07:14 AM
exhaust pipe question and reserve tank question killian101 Twins Technical Talk 2 07-05-2008 03:50 PM
