If it ain't broke don't fix it? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!
Old 12-09-2012, 06:01 PM   #1 (permalink)
Main Motorcycle: 1978 Triumph 750 Tiger
Other Motorcycle: Trident 900
Extra Motorcycle: 64 BSA B40 SS90
Hello there,
before I get started may I first thank all who contributed to my last thread about my sticking clutch as after a strip down, plates boil (plewsy style) and careful setting up it is now snicking into gear in the morning with no problems at all, although the cols weather and salty roads have put paid to riding for 3 or so months!
So I have started to draw up the list of winter jobs! Most of them are fairly trivial cosmetic stuff. I have one engine job to complete (take of the exhaust rocker box and helicoil one of the outer 1/4 unc threads) but I am also contemplating replacing the crank feed oil seal in the timing cover. My bike shows no signs of low oil pressure, the only reason I am possibly going to do this is as the bike is fairly new to me (9 months) I don't know it's condition/age.
So.......It ain't broke! But should I fix it?
My rational is,
1. If it does fail, big damage may occur.
2. It is cheap and easy to do.
3. Peace of mind once done.
Am I mad?
tommytiger is offline   Reply With Quote
Old 12-09-2012, 06:41 PM   #2 (permalink)
Main Motorcycle: 1978 Bonneville T140V
Morris the Cat's Avatar
Am I mad?
No - but you might be later.
You might as well replace the contact breaker seal while your at it.
Then you will have to re-assemble the c/b assembly and re-time the engine.
Make sure all is well before disassembly and mark the points backing plate (index it) to aid reassembly.
Morris of Main Street
Morris the Cat is offline   Reply With Quote
Old 12-09-2012, 08:56 PM   #3 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
My rational is,
Am I mad?
There's more chance of a new seal failing in the first 5 minutes,than there is of the old seal failing in the next 5 or 15 years.
Some seals won't stand the pressure,and become inverted (instant loss of oil pressure).
Mr.Pete is online now   Reply With Quote
Old 12-10-2012, 01:44 AM   #4 (permalink)
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
You want peace of mind?
Temporarily fit an oil pressure gauge, then go for a 20 mile ride. If pressure remains normal, remove the gauge and stop worrying.
Triton Thrasher is offline   Reply With Quote
Old 12-10-2012, 06:49 AM   #5 (permalink)
From what I can tell the crank seal is reliable so probably best just to leave alone. I do have a gauge I can fit, just for the record what kind of pressures should I be expecting?
Old 12-10-2012, 07:10 AM   #6 (permalink)
I'd go by what's in the book.
Old 12-10-2012, 09:54 AM   #7 (permalink)
I have composed the proper corollary statement to the age-old axiom "If it ain't broke..."
It is... "fix it 'till you are."
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 12-10-2012, 09:56 AM   #8 (permalink)
Main Motorcycle: T140 E
very true!!
DAVE M is offline   Reply With Quote
Broke down. mrbassett Twins Technical Talk 18 11-22-2012 12:17 AM
About broke in EFI Ducatiarte Twins Talk 0 09-26-2009 09:23 PM
i think i've broke it! :( millwallfcuk Trophy 9 07-24-2009 06:47 PM
HELP - broke off bar end markstaylor72 Speed Triple Forum 3 02-02-2009 09:41 PM
BROKE KEY OFF HELP! DahktahJay Sprint Forum 3 07-15-2005 04:54 PM
