bolting carbs to manifold question... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-09-2012, 03:14 AM   #1 (permalink)
Main Motorcycle: my 66' Triumph 650
Other Motorcycle: 2007 Harley softail
i'm putting new gaskets and o-rings on my carbs and re-mounting them. the previous owner had just a bolt (no washers) and those self tightening nuts (with nylon inserts).....i'm sure that helps prevent vibration from loosening the bolts over time. is this what was originally used on the carbs? i've heard that i only want about 7 lbs of torque on these bolts to prevent binding or warpage on flange (and possible slide problems. the problem is that these self tightening nuts screw on hard and it's difficult to tell when you have "bottomed out", and just how tight they really are...i'm curious about what you guys use on the carb mounting bolts and nuts, and the procedure. thanks, Rick
razman is offline   Reply With Quote
Old 12-09-2012, 04:41 AM   #2 (permalink)
Moderator
Main Motorcycle: T120V
Caulky's Avatar
Other Motorcycle: 1960 Tiger Cub
You have the screw-in manifold.
The bolts [F2603] have two plain washers [S25-3] each, nuts [T234].
Gasket [NA43A], Insulating block [E2968] and the O-ring [244/1048].
Do not overtighten.
http://www.scribd.com/doc/55885440/1...-Parts-Catalog
Caulky is offline   Reply With Quote
Old 12-09-2012, 01:21 PM   #3 (permalink)
Tiger Dale's Avatar
A great tip from GABMA is to use a split lock washer and tighten just until the washer collapses. Hope that makes sense.
td
Tiger Dale is offline   Reply With Quote
Old 12-09-2012, 02:07 PM   #4 (permalink)
ok, thanks.....but the self tightening or self locking nuts are the way to go right???
Old 12-09-2012, 02:48 PM   #5 (permalink)
Moderator
Caulky's Avatar
This is a picture of my set-up. (`74 T120V)
This is apparently from `69 on.
Your manifold is different to this.
But its not shown in my `72 or `73 spares books.
[it must be in the `74 T140 book which is in the workshop]
The cup is 70-9555 and the rubber insulator is 70-9554.
This is a far better method of fixing the carbs...you dont need to crush the rubbers much.
The nuts are 1/4 UNF`stiff nuts` I think.
The gap between the manifold and carb flange is due to the `thick` O-ring.
I imagine you could use the cups and rubbers...not sure about the O-ring or nut.
Your nuts may be a different thread???
Old 12-09-2012, 03:59 PM   #6 (permalink)
thanks Caulky for the pic......that's the type of nuts that i'm using, just worried about over tightening. i do have two different o-rings that i can use on these new 930 amals, but the thick one doesnt' seem to "seat" into the carb groove (too thick), so i guess i will use the thinner ones. the split washer method might be my best bet to determine torque on the carb flange....Rick
Old 12-09-2012, 09:16 PM   #7 (permalink)
Main Motorcycle: !967 T120
Other Motorcycle: Ducati 900ss 1978
Extra Motorcycle: Ducati Mk3 Diana
Carb Mounting
Use the thicker one and hold it in place with grease while fitting. Tighten it to the gap seen in the picture posted above. Does not need to be that tight. This will insulate from heat and vibration.
My .02 cents
Ken Reece is offline   Reply With Quote
bolting bar ends on a NH ace bar keithk Twins Technical Talk 0 04-13-2010 09:38 PM
A question about intake manifold length ohiorider Twins Technical Talk 19 07-29-2009 09:56 AM
Bolting a top box trunk to the passenger seat? Catamount Speed Triple Forum 12 05-16-2009 06:06 PM
Carb rubber manifold question BigDawg Hinckley Classic Triples 3 02-18-2009 05:16 PM
Another intake manifold question ohiorider Twins Technical Talk 9 04-07-2008 12:34 PM
