OIF removing studs at oil sump - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-08-2012, 01:20 PM   #1 (permalink)
Main Motorcycle: the one I'm riding
enuf's Avatar
Other Motorcycle: 2000 Honda VFR
Extra Motorcycle: 1989 Honda Hawk GT
Has anyone replaced the studs for the oil sump on the frame? I removed the oil filter and discovered to two bad studs.
Do they tend to break, while being removed?
Any secret for success?
enuf is offline   Reply With Quote
Old 12-08-2012, 07:47 PM   #2 (permalink)
Main Motorcycle: Triumph T140 & TR7
Other Motorcycle: Guzzi T3
Extra Motorcycle: Another Guzzi T3
Yes, I had to change one of these studs because of a bad looking thread. I was anxious just as you are, but as I had mine down to the bare frame I was willing to take a bit of a risk - if it had sheared off I could have taken the frame somewhere to get the broken bit removed. As it turned out it came out very nicely using a good quality pair of mole grips done up really tight. It is steel into steel, so unless there's a lot of rust (unlikely given the locatrion at the bottom of the oil tank), corrosion shouldn't be a problem. Get as good a grip as possible and unscrew - no reason why they should snap.
JohnA is online now   Reply With Quote
Old 12-08-2012, 08:43 PM   #3 (permalink)
Main Motorcycle: 1978 Bonneville T140V
Morris the Cat's Avatar
Bad studs have been over-torqued and they can prove it.
Heat and Cold treatment has worked for many a folk who don't want to take a chanceof ruining a stud with two different threads.
New studs would be great to prevent leaks. . .
If you had two bad studs then you also had an oil leak?
Morris of Main Street
Morris the Cat is online now   Reply With Quote
Old 12-10-2012, 09:21 AM   #4 (permalink)
enuf's Avatar
Thanks, for the info, amazing no major leak, studs out. looking for new replacements now.
Old 12-10-2012, 09:47 AM   #5 (permalink)
Main Motorcycle: '77 Bonneville T140V
Garioch43's Avatar
Mine were pretty chewed up when I came to renovate my T140V.
My 1976 parts manual has a mistake with the part number for these studs.
It quotes 21-2025. Should be 21-2109. Only cost a few bucks.
Sam Murray
Aberdeen, Scotland
Garioch43 is offline   Reply With Quote
Head Studs - which way up? Dave W Classic, Vintage & Veteran 2 11-30-2010 09:14 AM
manifold studs ARTEE Classic, Vintage & Veteran 3 12-09-2007 03:37 PM
Studs GeneralPig Hinckley Classic Triples 9 06-26-2007 11:09 AM
Studs GeneralPig Maintenance & Workshop Talk 1 06-24-2007 08:36 PM
Studs paulie Tiger Chat 4 02-04-2004 01:25 AM
