76 T140v Foot spindle oil drip - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-10-2012, 01:33 AM   #11 (permalink)
Main Motorcycle: 1976 Triumph Bonneville
furious furball's Avatar
Originally Posted by JohnA View Post
I think I see now: So you're saying that the oil comes out of the hole in the crankcase that's behind the clutch drum, where the crossover shaft emerges before its 'U' piece? This hole should have an iron bush at each end - best to make sure these are in place.
So, after the oil has come out of this hole, it then finds its way out of the drain plug-hole (the plug from which you have removed), and from there splatters all over the place or forms a pool if you park the bike on the sidestand?
Well, no significant quantity of oil should get through that shaft bore. It shouldn't be above the level of the bore at the gearbox cover end, and the gearbox shouldn't build up enough pressure to force oil through what should be the very small gap between the shaft and the iron bushes.
Have you got no more than 500ml of EP90 gearbox oil in the box? Do you know whether those iron bushes are ok? There should be NO appreciable slop between the shaft and the bushes at either end.
If I've understood the problem correctly and if all the above is AOK, I'm certainly stuck for ideas!
Yes John, that's exactly it. Both iron bushes are in place and there's no freeplay between the shaft and bushes/hole. The addition of the o-ring and the primary cover to hold the foot change spindle in place worked about 50% better - still had oil that came out but not nearly as much as without the o-ring. However, noticed a little difficulty in shifting gears sometimes and then sometimes not...more in the down shift then anything. Maybe a thinner o-ring? I'll experiment...now that I'm a dry clutch, going into it without having to drain is so much nicer.
furious furball is offline   Reply With Quote
Old 12-10-2012, 01:38 AM   #12 (permalink)
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
As John mentions, are you using thick gear oil?
Triton Thrasher is offline   Reply With Quote
Old 12-10-2012, 01:44 PM   #13 (permalink)
Main Motorcycle: Triumph T140 & TR7
Other Motorcycle: Guzzi T3
Extra Motorcycle: Another Guzzi T3
Here's a suddent thought... Are you sure the oil is coming from the gearbox? I'm wondering whether it is simply coming through the drive side main bearing. How did you seal this when you converted to a dry clutch & belt drive? And what did you do for crankcase breathing after sealing the main bearing (and the three little holes that are there to allow oil to drain back into the crankcases once the chaincase is at the right level)?
JohnA is offline   Reply With Quote
Old 12-10-2012, 03:22 PM   #14 (permalink)
Main Motorcycle: 72 tiger
Other Motorcycle: 06 KLR 650
Extra Motorcycle: Guzzi 850 T
He indicates he fitted a mainseal but if its not vented crankcase pressure could be high. Maybe fit a breather on the timing hole.
That gear oil really travels. Probably just wicking along shift shaft
dl.allen is offline   Reply With Quote
Old 12-11-2012, 06:05 AM   #15 (permalink)
Main Motorcycle: T140 E
it's a 76 so is LH gear change with the x over shaft.
That must be a lot of wicking?
DAVE M is online now   Reply With Quote
Moving '74 t140v foot pegs bjordan9 Classic, Vintage & Veteran 6 10-27-2012 08:51 AM
1978 T140V: Torque setting for rear wheel spindle nut SirSwift93 Vintage Technical Tips & Tricks 3 03-21-2011 12:51 AM
'73 T140v clutch foot control sticky/stuck Mad Daego Classic, Vintage & Veteran 14 09-30-2010 06:56 AM
Replacing Rocker Spindle - T140V Dave W Classic, Vintage & Veteran 0 08-01-2010 11:18 AM
Fuel Fittings.........DRIP DRIP ken750f Speed Triple Forum 13 09-13-2005 12:20 AM
