push fit air filters - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-04-2012, 08:45 AM   #1 (permalink)
Main Motorcycle: BONNIE 1979 T140E
Anyone any experience with these?
I am deciding between the original setup
which I personally find cumbersome or
the simpler push type?
What are the downsides? Jetting?
Thanks in advance.
Happy winter riding!!
Ed.
eddyfiola is offline   Reply With Quote
Old 12-04-2012, 12:39 PM   #2 (permalink)
Main Motorcycle: T140 E
Assuming that you have Mk2 carbs and a parallel head then you may have problems fitting different filters. Whatever you fit, the jetting may be changed - it depends on the filter.
You can (I think) fit TSS rubbers that kick the carbs out - splayed head style.
Then you could fit K&Ns or whatever.
DAVE M is offline   Reply With Quote
Old 12-04-2012, 12:49 PM   #3 (permalink)
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
There's a K&N, specified for the Norton Commando and 6-cylinder Triumph TR sports cars. I've heard it can be fitted to a T140E
I use it on my T110 with twin MkI Amals on parallel ports.
Looks like this:
Triton Thrasher is offline   Reply With Quote
Old 12-04-2012, 02:01 PM   #4 (permalink)
looks interesting.
there's not much room between the carbs as the OIF is in the way
Old 12-04-2012, 02:50 PM   #5 (permalink)
Originally Posted by DAVE M View Post
looks interesting.
The filter dimensions will be on K&N's pages.
Old 12-04-2012, 07:27 PM   #6 (permalink)
That is exactly what I am looking for, thanks.
Will check it out.
Old 12-05-2012, 04:32 PM   #7 (permalink)
Main Motorcycle: 71 bonnie
you will need to re-jet with that k&n filter
tintop48 is offline   Reply With Quote
push rod placement.... LimeySoul Classic, Vintage & Veteran 5 10-02-2008 09:03 AM
Push-in push-over ?! Drama... happyray Classic, Vintage & Veteran 2 06-04-2008 03:27 PM
Dudes, Help, I need a push! gobucks Speed Triple Forum 10 04-02-2008 09:37 PM
I cant push my bike ! BadDog Maintenance & Workshop Talk 12 02-08-2006 04:13 PM
push starting superdave1018 Speed Triple Forum 8 10-04-2005 06:15 PM
