68 front end size - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-27-2012, 05:55 PM   #1 (permalink)
Main Motorcycle: 68 triumph bobber
68 front end size
I'm new to triumphs and a new owner/builder. I just picked up a 68 bonneville 750, and want to start working on this as a winter project.
The motor is good, and sitting in a ridged bolt on. Main issue is the tins, I guess the guy wanted a Harley so he tossed a fat low rider tank and a pan style fender with a big 2 up seat on this 68.
I'm pulling all the ****ty tins off and gonna put a triumph tank, smaller rear fender and solo spring seat.
I'm looking around for front ends, maybe a springer if I find one. My question is what size front ends will fit in the 68 neck?
Please be kind cause plenty of stupid questions will be coming forth from me.
Cash43 is offline   Reply With Quote
Old 11-27-2012, 09:08 PM   #2 (permalink)
Main Motorcycle: 1978 Bonneville T140V
Morris the Cat's Avatar
Cool
Originally Posted by Cash43
68 bonneville 750
Not sure about the front -end but a '68 and a 750 cc engine is not the norm.
Aftermarket hop-up kit or more modern(?) engine?
Some pictures of what you have might help. . .
http://www.jockeyjournal.com/, might be of more help with this kind of question, or at least, good reference and reading material.
Morris of Main Street
Morris the Cat is offline   Reply With Quote
Old 11-27-2012, 10:21 PM   #3 (permalink)
From what I've read the 68 T120r came in a 750cc
Old 11-28-2012, 08:54 AM   #4 (permalink)
Main Motorcycle: 1968 Bonneville T120R
68T120R's Avatar
Other Motorcycle: 2010 Jet Black T100
Extra Motorcycle: 2013 Black Tiger 800
I am curious where you read Triumph made a 750cc T120R in 1968? I am certainly not familiar with that being the case and I have read a lot about 1968 T120R's since I have one. I don't believe Triumph produced a 750cc Bonnevillle until the early 70's.
Front tire size for a 1968 T120R is 3.25 x 19 and rear is 4.00 x 18 per the owners manual.
Bob
2010 Jet Black T100, BC Sleepers, BC Air Box Elimination, BC Air Injection Removal, Triumph Mapping, Hagon Classic Shocks, Hagon Progressive Fork Springs, CRG LS Bar End Mirrors, LHP Directional Relocate, Lucas Tail Light, Triumph Centre Stand
68T120R is offline   Reply With Quote
Old 11-28-2012, 09:02 AM   #5 (permalink)
Main Motorcycle: T140 E
I assume that you have a converted 650.
After market suppliers sold bar barrel and piston kits, the idea was pinched by Triumph, and in the early 70's the T140 was born.
or you have a genuine T140 engine in an earlier frame.
Post pictures of the engine number/frame and someone can tell you
The front ends between the non OIF and OIF bikes are not the same but I believe that the T150/60 yokes fit the earlier frames.
DAVE M is offline   Reply With Quote
Old 11-28-2012, 09:19 AM   #6 (permalink)
The engine number is T120r du76543
Old 11-28-2012, 09:28 AM   #7 (permalink)
Here's the frame (working off iPhone so not sure if pics are loading correct)
Old 11-28-2012, 09:37 AM   #8 (permalink)
Main Motorcycle: 1971 Bonneville
therabbithole's Avatar
Extra Motorcycle: 1970 CL350
did the previous owner tell you it was a 750? closer-up pictures might help some of the more knowledgeable folks tell you if the barrels were aftermarket displacement upgrade. or maybe it's still the original 650...
your forks look like they're already 73-or-later (disc brake and one-piece aluminum legs) so you might already have non-original triples, too. i suspect more pictures would help in that regard as well.
therabbithole is offline   Reply With Quote
Old 11-28-2012, 09:55 AM   #9 (permalink)
Main Motorcycle: T140V Bonny '77
obollox's Avatar
Other Motorcycle: T120R '71
Where did your info come from? I think you will find the 750s were first produced in 1973 and were actually 724cc. Why do you think yours is a 750?
obollox is offline   Reply With Quote
Old 11-28-2012, 10:10 AM   #10 (permalink)
I know the front end is newer, off a Honda I believe... As far as it being a 750cc I'm going off what the seller stated. I just picked it up a few days ago so I haven't ripped into it much
GT Front spring size taximan62 Sprint Forum 3 06-15-2012 04:24 AM
front sprocket nut size Andy-Brad Triumph SuperSports 1 05-25-2011 07:01 AM
Front tyre size oz. Trophy 0 12-12-2010 03:44 PM
Front stand pin size? KVT Sprint Forum 8 08-04-2010 06:33 PM
front axle size farmhand777 Speed Triple Forum 1 10-19-2006 12:29 AM
